Old 05-02-2018, 05:04 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Corrosion in the servo motor
Rick (the customer) is correct, and the cause was mild corrosion in the motor itself. It is impossible for us to know how it came to be corroded. Turning on the servo freed it, and if the corrosion was worse to completely immobilize the motor, the shear screw is there to free the controls when enough force is applied. Admittedly, the language on the repair type checkbox is a bit terse. "Installation Induced Failure" is really a catch-all for things that we can see a clear installation, environmental, or other explainable cause that we wouldn't attribute to a defect in materials or workmanship.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 05-02-2018, 06:28 PM
Toobuilder's Avatar
Many thanks for clearing that up.
Michael Robinson
______________
RV-8 - Flying
