Old 11-26-2017, 01:40 PM
SteveT SteveT is offline
Default Die Grinder - Front vs Rear Exhaust
Im shopping die grinders and considering the pros and cons of front and rear exhaust. Which do you prefer, and why?
And while were at it, any feedback from those who own an Ingersoll Rand 307B and/or 301B?
Steve Thompson
Scottsdale, Arizona
RV-14 #140437 - building the empennage
N45KK reserved
http://www.airplanebuild.com
Old 11-26-2017, 05:02 PM
wirejock's Avatar
wirejock wirejock is offline
Default Die grinder
Rear if possible. Front blows oil all over the parts. Actually, I prefer an electric or battery. My air grinder and cut off tools are air hogs.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-27-2017, 06:48 AM
I have a 301B 90 degree Ingersoll Rand I bought in the 80's when I used it daily for grinding corrosion on the big jets. I use it all the time, and it is very reliable, controllable and lightweight. If you get used to using the 90 degree type, you will never even pull a straight die grinder out again. I couldnt live without it, and working with Scotchbrite pads and sanders, you wont need another finishing tool in your bag. I often wrap a small cloth around it when working for two reasons..it will get cold, and the cloth will disperse exhaust and any oil ( don't over oil them) .
Bill E.
RV-4/N76WE
41 Aeronca 65TC Defender
8A7 / Advance NC
Old 11-27-2017, 09:22 AM
az_gila's Avatar
az_gila az_gila is offline
I'll go a bit against the grain here...
This is one case where Harbor Freight cheap tools work well. We don't need the power of a full-size hand held grinder, the compact HF ones are fine and lighter in the hand.
https://www.harborfreight.com/air-to...der-62439.html
https://www.harborfreight.com/air-to...der-52847.html
Use minimal oil to keep your work clean - especially on fiberglass - and simply buy a new one when it wears out. You can buy 3 for the price of the IR one.
PS I'm still using my 20+ year old HF compact die grinders, and IIRC they were about the same price as now when I bought them. They got lots of use on a non-punched -6A kit, mainly with 2 inch Roloc disks.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-27-2017, 10:00 AM
gasman gasman is offline
USAF..... oil, 3 drops per day.
VAF #897
2017 =VAF= Dues PAID
Old 11-27-2017, 10:34 AM
az_gila's Avatar
Smile
Cheap HF grinder - 2 drops after a long time on the shelf - less mess.
Also, we are usually not using these tools on a full work day of 8 hours. Just consider the HF tools as cheap disposable tools, but they work well.
I learned this from one of the best sailplane repair guys in the US. He used DA sanders and various grinders, and was so concerned about oil contamination on the glass structures he was repairing with 50:1 scarf joints that he never oiled his sander/grinder, he just bought new ones as needed.
Gil Alexander
