Pat Stewart
Installing a dual Skyview system with a Shunt. I think I know what to do on this issue but double checking. The drawing I have is not clear on the #8 wire going to the Advaced Control module. I am running the alternator wire to a 60amp breaker and back to the shunt. Master relay and starter relay are tied together like the normal OP 10 drawing however not sure where to tie the wire from the ACM back to. Just never wired anything with a Shunt in the past.
