Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-28-2017, 08:19 AM
deej's Avatar
deej deej is offline
A friend showed me the HUD in his new Prius last weekend, and after seeing Greg's announcement and the 30 day return policy from Hudly, I decided to order one for my truck (2011 Ford Ranger). I ordered the OBD2 powered unit with the iPhone interface.
I installed it yesterday, so this is more of a first impression review rather than one with much experience.
I now have an OAT display in my truck, which is something I've wanted for awhile. :-)
Hudly has two recommended mounting positions for the projector, both of which placed the projector in my line of site looking out the window. This will vary depending on how high the seats are in your vehicle, and how tall you are, but in my case I determined that it presented a safety hazard. After placing the projector and screen in a variety of places to test, I ended up mounting it behind the left side of the rear view mirror with about half of the projector visible below the mirror. I was careful to preserve the angles and distances between the projector and screen as laid out by the paper template they provide.
The display is bright, and I had no trouble seeing it in the bright sunlight this morning. I have not yet tried it at night.
Due to the curved nature of the projection screen, it is hard to get a perfect image. However, with large icons/numbers, the display is very usable. My default is the OBD2 info with speed, rpms, and OAT. Running an app on the iPhone like Google Maps is usable viewing the map, although reading the small text is more difficult, but bear in mind that the Google Maps app is not optimized for a HUD display. I'm hoping to test more apps over the next few days.
It has a somewhat limited field of view. I could move my head about 2 inches in either direction before the edges of the image became distorted/fuzzy or started to get cut off. This will likely vary depending on the distance between your head and the projection screen, and possibly the mounting location.
My wife came out and asked me what I was tinkering with, so I let her try it. She is shorter than I am and could not see much of the display without boosting herself up a bit in the seat, so the screen will have to be adjusted for each driver. On the positive side the adjustment of the projection screen is easy to do, but on the negative you can't reach the screen when sitting in a normal driving position so it takes a few attempts to get it adjusted properly.
There is a difference in focal distance between the outside world and the HUD display. My wife wears bifocals, and was having a hard time seeing it. I wear single prescription glasses and did not have that problem, but did note my eyes changing focus when moving back and forth between looking at a vehicle in front of me and the HUD. I found that quick glances worked better than trying to focus on it, especially when you have large numbers being displayed like the speed or temperature.
I also noticed that each eye was seeing a slightly different image, again presuming this has something to do with the curved screen. What I mean by this is that closing one eye then opening it and closing the other to compare the images, you could see slight differences in the edges of the image. This made it harder to focus directly on the screen, but using the quick glance method seems to work well.
Another observation is that it is a "floating" display, which means that when you move your head, the image appears to move slightly. It is a bit disorienting at first but I suspect that with more use this will not be an issue.
Since it has speakers built in I was hoping that I could use it as a hands-free device for phone calls, but this does not seem to be the case (and nowhere does Hudly claim it will do this). The projector speakers do work for playing music, voice from turn by turn directions, etc, but they are of poor quality. The speakers in the iPhone are better, IMHO.
The iPhone does get charged when plugged into the HUD.
Overall I think a lot of people will like it, and others will not. I haven't yet decided if I want one in my Glastar tied to the GRT HX, and am hoping that more experience with it in the truck will help with that decision.
-Dj
Old 07-28-2017, 09:57 AM
Thanks for providing this feedback, Dj.
At this stage in our build I've had to enforce a "no more changes" rule so I won't be jumping on this bandwagon immediately - getting the airplane flying is of utmost importance. In the meantime I'm going to be paying very close attention to the experiences of others.
Thanks again for posting the feedback.
Old 08-02-2017, 12:20 PM
BHunt BHunt is offline
How soon until Dynon/AFS get in on this?
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 08-02-2017, 02:18 PM
painless painless is offline
My wish list has one major item. Eliminate the need for a droid device and have the projector communicate directly with the EFIS. This will require a hardware upgrade by Hudly, but Greg has their attention, so I'm holding off purchase until the dust settles.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 08-02-2017, 02:29 PM
maniago's Avatar
maniago maniago is offline
They wouldnt bite on the glasses stuff, even tho GRT did. My guess is they'll wait a long time before they do this. For sure, the HUD is way better than the glasses ever were.
Now if Garmin goes for it, everyone will have them in an instant.
Mani
Bushby Mustang II (building); IO-360B1E, C2YR-BF/F7666-2
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2016
Old 08-03-2017, 07:54 AM
KRviator's Avatar
KRviator KRviator is offline
I'm not sure...Without actually trying them on to see if there are any downsides, I reckon would prefer the glasses, that way you have PFD information anywhere you are looking, rather than just through the HUD. I'm somewhat disappointed that Dynon's 'only' announcement at Oshkosh was they're moving into the certified market - not that that is a bad thing, but I was hoping for something for us too. Like maybe AR glasses or something...
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 08-13-2017, 07:25 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
The proper term is Head (singular) Up Display, meaning that the pilot can see it with the head up. "Heads Up!" means "look out!"
Common error, but worth fixing.
Ed
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2017 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 08-13-2017, 09:47 PM
Originally Posted by Ed_Wischmeyer View Post
but worth fixing.
Ed
... not sure about that.
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 08-13-2017, 11:07 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Agree. It's too late, heads up display is already ingrained in our speech. Reminds me of a few years back when we first started seeing all the nice big tv screens. The correct term was flat panel TV; flat screen TV was something else. Didn't make any difference, people kept saying flat screen and it stuck.
Erich
