I've been noticing that my Skyview trim indication is starting to jump around a bit while setting it to the take off position. The trim up and trim down switches are still providing smooth movement of the pushrod and trim/servo assembly, but the indicator bounces around quite a bit, and even fails to move with some small trim adjustments. My guess is that there is a wire wound rheostat inside of the little black trim assembly. I thought about squirting a little contact cleaner in there, but I thought it best to seek a little advice first. Also, I was wondering if this is an isolated case. Thanks for any thoughts.........Tom
