Empennage trim servo and tail light wire harness
Carlpretzel
Patron
Ok I finally finished the lower fuselage riveting. The tailcone kicked my ***. I did not pre run the trim servo/tail nav light wire harness:( to be honest I don't like how the wires are run. I was thinking of using clamps on the outside of the J channel instead. Thoughts? Or better yet anyone have some photos showing how they ran this harness. Also, I think some of the wires going forward are too short?
Ok just an FYI if anyone does the same thing I did. You can fish the trim servo connector under the "J" channel at each bulkhead. Just take your time.
Two wires that go forward are too short in the early kits at least. I was sent a two wire WH-00057 'fix kit'. Just crimped them on to the existing wires and then they were long enough.
I did the wire run per the plans and I thought it worked well.
