We are working along on the 14A and it will be a long while till our 390 motor and prop arrive because the ordering and delivery time from Lycoming. My question for the brain trust is: Do you think it would be OK to build the whole nose assembly without the motor? I will have no idea if the hole in the front is centered. I would be depending on the straight edges of the peaces are supplied by Vans. I plan to build it with the Van's supplied hinge set up.
It would be great to plow forward - but don't know if that it is the right thing to do? Hopefully some of you would know.
Thanks, Larry
Thanks, Larry
