swisseagle
Hello
I just was wondering, where should I place a balance weight?
My Vans Spinner Backplate does not have holes to place the balance-weight. Is it ok to make a circle of holes, prior mounting?
That way I would be ready to install weights if needed. And I do not think it harm the integrity of the back plate.
Or can I use these holes:
But these are AN4, so maybe a bit heavy to correct small amounts. Can I install two screw's opposit each other and only place a washer on one additionaly. Would that be ok?
Or what are you doing if there are no holes around ...
Thanks for your input.
