burgessbuilderMO13
Active Member
Just started working on the nose gear fairing, and came to the steps where there is a hole drilled and tapped in the gear leg to secure the fairing. Really?
Has anyone done this, as it seems to me a good starting point for a stress riser in the making. Has anyone developed an alternative scheme to retain the fairing position. I am thinking of a fiberglass rib setup near the top of the leg where the bent is below the lower weldment.
Thanks for any ideas.
