Old 08-15-2017, 10:54 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Originally Posted by NorthernRV4 View Post
Darn that plane is GORGEOUS! Any info on those main wing fillets? custom job? they are just icing on the cake to me.
Those are Team Rocket wing root fillets. Contact me at vince@f1aircraft.com if you'd like a set.
No PMs please.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 01-26-2018, 12:23 PM
gotime242 gotime242 is offline
Will a CS prop be required for CG or would something like a Catto be a possibility?
Old 01-26-2018, 02:46 PM
patterson patterson is offline
Default Catto for me
GO time,
I am using a Catto Fixed Pitch prop on my plane. I had one on my RV-4 and it was great. I'll let you know how it works out.
Ron
RV-4 N8ZD Sold
F4 Raider under construction
regular VAF donor despite being exempt
Old 01-27-2018, 08:10 PM
vfrazier's Avatar
I'd plan on a CS prop to be on the safe side, but there are many ways to make adjustments.
Vince Frazier
www.f1aircraft.com
Old 01-29-2018, 04:03 PM
Thanks!
I wonder what angle valve / catto / smoke tank + batt would look like up front cg wise..
Old 01-29-2018, 09:00 PM
vfrazier's Avatar
Thanks!
The battery is up front on the F4s.
The angle valve won't fit inside the cowling. Sorry. I guess you could make a new cowling, but it'd be a helluva lot easier to use a parallel valve and just put in a baggage compartment, or inverted oil system, or lead brick, or a flywheel weight, or just use a constant speed prop.
No offense to Catto's very fine products intended!!! Hmmm, if only they started making CS props too... yeah, that's the ticket!
Vince Frazier
www.f1aircraft.com
Old 01-29-2018, 09:22 PM
AX-O's Avatar
AX-O AX-O is offline
They are building constant speed props. Very few though. They are also going through the process for FAA certification. When both of those go into full swing, look out. I just spent 10 days there doing an “internship” (building my other project).
Btw, would love to build an F4.
Axel
RV-4 fastback thread and Pics
West Coast Ravens
VAF 2017 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 01-30-2018, 11:24 AM
Ah gotcha, ok good to know, thanks!
Old 02-01-2018, 04:19 PM
vfrazier's Avatar
I had heard the rumors about the new props. Good for them! Yay!
Vince Frazier
www.f1aircraft.com
