Old 04-19-2011, 07:21 PM
aerhed aerhed is offline
Jeff, thanks for the pic.
Troy, yes I have the spacers. The head of the socket bolts sits about 1/4? inside the fairing. I solved the hand towbar thing today like this.
Actual repeat offender.
Old 04-19-2011, 07:47 PM
TSwezey TSwezey is offline
Originally Posted by Jeff Vaughan View Post
Here is what I did. Have not tested it in big winds.
Mine melted for some reason! I had a screw cap on the end so you could tighten it and I had a little J that held the stick forward and kept the stick from moving side to side also.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 04-20-2011, 07:52 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
I am trying to figure out why you need this attachment to the tow bar. Something is not right. Do you have a pic of your nose gear with the pant off?
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 04-20-2011, 08:43 PM
PHP Code:
No pic handy, but like I said before the tip of the socket bolt is just below the surface of the hole. What it is, is that the cups on the towbar are short and they don't bottom against the fork. That lets the arms of the towbar scrape the sides of the fairing. Bogert makes different models of bars and this one must just be wrong.
Old 05-15-2011, 07:21 PM
TroyBranch's Avatar
Default Finaly pics of Aileron and Rudder lock
Here is a shot of my aileron gust lock that works very well. I put one on each aileron. Aluminum, dowl, a little bungy and you are set. There is no way it will come off in the wind. It is important to have one on each aileron as the control system will still take a beating otherwise. Two also puts less load on the lock.
Looking from the top.
Trailing end view.
Looking through the hinge.
New rudder lock. I just made this so I can now have the rudder aligned with the vertical stab so I can still put the airgizmo gust lock on the outside. The purchased internal lock made the rudder have an offset. I now had dual reduntancy for ever control surface. Might seem over bored, but when you get half of your gust locks blown off in strong winds, you may think the same.
Troy Branch
950hrs Plus
CC EX-2 Flying
RV9 Built and Sold
Dues paid Nov 2019
Old 05-15-2011, 10:17 PM
paul330 paul330 is offline
Nice ideas - I'll definitely steal them!
Just a thought. Looking at the last photo, would it be possible to fit a cross piece so it's braced both ways and fix it to the control column as well? That would give just one lock which would secure all three axes.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 05-16-2011, 04:44 AM
pierre smith's Avatar
Default There's a better rudder stop
Seems that quite a few -10's shear the wimpy little rudder stops from Van's, including mine, so we came up with this:
Actually, we copied it and I cut it out of 1/2" thick UHMW and belt sanded it thinner, to fit between the upper and lower hinge brackets, then held it in place with two AN-3 bolts that go through both hinge brackets...much tougher. It is a one-piece, U-shaped bracket and clears the hinge on the rudder.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15 Sold
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-16-2011, 06:43 AM
TroyBranch's Avatar
With the stick in the forward position that should work. It does add to the possibility of knocking the lock out of place. For quick stops it would be better than nothing but I would not leave it that way over night. The other issue is the control system is still taking the load.
As for beefing up the rudder stop. Just imagine how much how much load it must take to brake the original. The rudder is really getting bounced around in the wind. I hope with my plan, the rudder will never touch the stop.
Troy Branch
950hrs Plus
CC EX-2 Flying
RV9 Built and Sold
Dues paid Nov 2019
Old 05-16-2011, 08:26 AM
Hmmm. So why not fit a similar lock as on the ailerons to the elevators and rudder? OK, you can't reach the top of the rudder without some effort, but would not one bracket on the bottom secure it effectively?
Paul
2019 Donation Made
Old 05-16-2011, 08:58 AM
Strasnuts Strasnuts is offline
Default Rudder stops
I made my rudder stop out of one piece instead of two. It would have to shear five to six rivets to break instead of two to three. Easy to fab too.
A&P RV-10 Flying 950 hours
SuperSTOL Flying 100 hours
