Old 12-30-2010, 07:09 AM
Auburntsts's Avatar
There have also been issues with wobbily steps (the cause of which is open to debate, do a search and you can read more). Putting in an access hatch allows for future access if wobbily step syndrome occurs. Of course you can always go without and drill out the floor if you need to, but this is one of those an ounce of prevention is better than a pound of cure kind of things IMO.
Todd “I drink and know things” Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 12-30-2010, 06:16 PM
9GT's Avatar
9GT 9GT is online now
I worried about this for some time also but today was the day of reckoning and I decided to install per Van's method with a #30 locate hole above and and below, and if the time comes where I ever need to remove the step, I will either open the holes up to to 3/4" to gain access to the bolt & nut, or just cut out and install an access plate at that time. I will re-weld the crappy current welds on the steps prior to permanent installation so they will probably never need to come out,,,,, and if they do its no big deal. I have found with the previous plane I built that those little added ounces you add here and there add up quick and I am trying to keep this one light.
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
Old 12-31-2010, 05:46 PM
N427EF N427EF is offline
Default Add lightness
Keeping it light will work especially well in this instance.
How about weld a MS21042 lock nut to the step tube on the top side.
Remove some aluminum about an inch in diameter to gain access on the bottom and your installation will probably be lighter than stock.
This is what I would do, if I had not already finished that part.
Your idea of drilling a pilot hole at this time is a great idea for future maintenance.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Don't believe everything you know.
