Old 03-24-2020, 10:39 AM
FinnFlyer FinnFlyer is offline
Default DIY Comm antenna?
I was planning on making my own comm antenna to be mounted on the turtle deck of my RV-4 below the canopy and following the canopy forward.
I thought a thin wire would do it, but after reading some Kitplane articles it looks like the thinner the antenna, the narrower the bandwidth. So 1/2" or wider copper tape seems indicated, but can't really attach the tape to the canopy and still have the turtle deck as a ground plane?
Mounting it on the side of the canopy, the rollover bar will be close to the antenna tip.
Wing tip mounting does not lend itself to a vertical antenna either (and a longer cable run to boot).
Any ideas (other than spending $120 or more on a Delta Pop antenna hanging out in the breeze)?
Finn
RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 03-24-2020, 10:54 AM
Mel's Avatar
Mel Mel is online now
Spend the money and hang the antenna "out in the breeze"! You won't notice the minimal drag and the performance will be sooooo much better.
Home made antennas work OK for receive, but not so much for transmit where VSWR is important.
A&P/BGI/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 03-24-2020, 11:14 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Any ideas (other than spending $120 or more on a Delta Pop antenna hanging out in the breeze)?Finn
Jim Weir is Da man and contributes to Kit plane. He has written about this for decades. He had RST kits and still sells some things. He is a kit for $29 that is enough to make several antennas (VOR, LOC, COM, MB). Check the link below and the link to instructions. He spends a lot of time on VOR "Dipole").
http://www.rstengineering.com/rst/pr...aneantenna.htm
Of course buying an antenna and bolting it on to the belly or turtle deck will be easy, have best performance and the drag I once calculated decades ago. I think we are talking 0.25 mph off top speed. Speed With Economy has numbers. This will be a compromise over a regular VHF mono-pole antenna bolted to the belly or turtle deck with a solid large ground plane which is about 23" inches in all directions. Not discouraging you.
Yep you are right a flat copper tape strip is better than thin wire, so I read like you. I do wounder how much "bandwidth" you are loosing. Voice AM (which is what we are doing) is not Hi-Fi. However since 3M makes sticky back copper tape it is kind of a no brain'er.
The RV-4 (which I flew a bunch but with belly antenna) has a tip over canopy. I can picture the challenge. I'm building a RV-7 slider so putting the antenna in the fixed front windscreen is easier, but the front bow might cause some dead spots. The better canopy is the tip up and using the glare shield as a ground plane. I like a strong radio, so I am going with a VHF antenna on belly.
You will have to terminate the strip and transition to 50 ohm coaxial. It will be an END FED (unbalanced) antenna and requires a ground plane. You will have to bring the feed line to the hinge line, into cockpit and run to your radio, no big deal. You have the cockpit edge longeron to run the coaxial under. The ground plane will be a creative exercise and challenge. You could ground it to the metal skirt around the back of the canopy but really want to tie it to fuselage turtle deck (ground). Also you may be grounding the canopy frame. Not sure what that will do. It could be goodness! It may be possible when you close the canopy you have a ground contact that grounds the skirt to the turtle deck>
Running the antenna over the canopy in the middle near the roll bar may cause some dead directions but you won't know until you try. It should work over 270 degree arc from front to back and off right hand side. I don't think it is worse than the buried antenna in one wing tip idea. Everyone says the wing tip antenna "works". By "work" they mean they can talk to the tower in the pattern, but forget getting out 10-20 miles at low altitude.
Find a HAM operator near you who has an antenna analyzer to test your antenna for SWR and Impedance. You understand about antenna length vs Freq. It is fun project, can be done cheap, you will learn a lot, even if you revert to a stick in the breeze. Again drag from one com antenna can't be measured it's so small but it is well under 1/2 mph. BTW I had a VOR dipole on the belly under the horizontal stab out in the breeze. When I did a few cross country races I took it off. If you are a speed demon you can take a com antenna off to race and use a handheld.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 03-24-2020, 11:45 AM
Ralph Inkster Ralph Inkster is offline
Clear communications is worth the price of a good antenna!
Ralph
It's time to work on just my own planes, not everybody else's...
Old 03-24-2020, 02:29 PM
9GT's Avatar
9GT 9GT is offline
Amen to that. Nothing aggravates me more than trying to decipher garbled, or poor quality radio transmissions from other aircraft.
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
Old 03-24-2020, 03:02 PM
Northernliving Northernliving is offline
I think George is right. If you find a HAM radio guy to help you tune an antenna (like a Bob Archer wing tip antenna), they can work extreamily well. The key is tuning it and getting it just right. I have an "out in the breeze" belly antenna that I'm underwelmed with. It works okay with just about every place but my class D home airport when on the ground. It's very frustrating. I wish I had one mounted elsewhere. I'll be working my my brother who is oild time vaccum tube, di-pole HAM guy to tune a wingtip antenna for my second radio.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 03-24-2020, 03:26 PM
Captain Avgas Captain Avgas is offline
Finn
Mate, if you’re worried about spending $120 on a comm antenna...well, you really need to ask yourself if you’re in the right sport.
Regards
Bob Barrow
RV7A
Old 03-24-2020, 04:06 PM
Default Handheld
"If you are a speed demon you can take a com antenna off to race and use a handheld."
Funny you should mention that, George.
I flew my old RV-3 for 575 hours with nothing but a handheld Icom mounted front/left on the canopy frame, rubber duck antenna sticking up clear of the canopy skirt. (I removed its battery case and made a mount to slide it on that also fed it 12 volts). Of course adapters and wiring to jacks for a headset. I wish I could find an old picture to scan.
Never had an issue.
"Speed With Economy has numbers"
5 mph! Page 149. Well, that's Comm, VOR and Loran His guess was 2mph for the comm antenna.
"Mate, if you’re worried about spending $120 on a comm antenna...well, you really need to ask yourself if you’re in the right sport. "
$120 here, $1,400 for ADSB-Out there, ... it all adds up
I'll re-read Jim's instructions. May even build my own SWR meter
Finn
RV-4 -- Building
Old 03-24-2020, 04:28 PM
Jpm757 Jpm757 is offline
Seriously, here's one from Spruce for $85 bucks! If that's not in your budget then maybe owning an RV is over your head.
.jpg](https://postimg.cc/Cn5MdJdM)
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 03-24-2020, 04:34 PM
Yep you are right a flat copper tape strip is better than thin wire, so I read like you. I do wounder how much "bandwidth" you are loosing. Voice AM (which is what we are doing) is not Hi-Fi. .
‘Bandwidth’, as used wrt antenna performance, means how well it performs at 118 and 135 MHz, when cut to spec for 126 MHz. Up to a point, using wide conductors, as opposed to thin wire, can improve this somewhat. ‘Bandwidth’, as used wrt the audio frequencies passed by our com receivers, is a function of the filters used within the radio. With aviation coms the bandwidth is deliberately limited to improve signal to noise ratios.
For poster #6. I also have a belly whip and an Archer-clone wingtip antenna, for com 1 and com 2, respectively. The external whip is generally better, especially beyond 25 nm or so. I have also encountered, but rarely, trouble using the belly whip when on the ground. Rotating the airplane 30 deg has always fixed the problem. (Might also be how much rebar was below the antenna!). If you install an Archer com, make certain you bend the antenna, to get as much vertical throw as possible in the leading edge (where the current is the highest) of the radiating element. In my -10, I mounted the ground element against the end rib as high as possible, then bent the radiating elements down until they were against the bottom of the wingtip. Getting as much vertical polarization as possible is important.
