Old 03-13-2020, 03:26 AM
jelliott82 jelliott82 is offline
Default Garmin GTR200 Mic / Intercom Issue
Hello
My Garmin GTR200 Mic Input / Intercom function isn't working. When I connect my 2x Bose A20 headsets and try to talk to one another there is no mic audio transmitting across the intercom from either headset. Are there any specific settings or configuration I should be setting on either the Bose A20's or the GTR200 / G3X, or should this just work and I need to review my wiring? The wiring was completed as per the wiring schematic in the G3X installation manual .. unless I made an error during the install.
I haven't yet tried the mic while transmitting.
Jonathan
Old 03-13-2020, 06:02 AM
jliltd jliltd is offline
Did you enter the GTR 200's "Configuration Mode" and go to the "Audio Setup" page to enable the intercom function? This is found in section 3.6.4 and 3.6.4.3 of the GTR 200/200B Installation Manual.
To enter Configuration Mode on the GTR 200, starting with the unit powered off press and hold the small rotary knob and then power on the device. Release the small knob when the display activates.
You mentioned using the G3X installation manual for your wiring but make sure to also get a copy of the "GTR 200/200B Installation Manual".
You will love this unit once it is up and running right.
RV-8
RV-3B
Old 03-13-2020, 10:54 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Power sequence
I have a Zulu and clarity aloft headset setup with the GTR 200. I have to turn on the Zulu power after the GTR is powered on for the intercom function to work. Not a big deal.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 03-13-2020, 12:24 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GTR 200 Intercom
Originally Posted by jelliott82 View Post
Hello
Jonathan
Jonathan,
We take it this is a single COM installation with no audio panel. As others have mentioned, the intercom must be enabled in the GTR 200 for it to work. There are some other troubleshooting steps we can work through if the intercom is enabled and not working. The intercom can be enabled by powering on the unit while holding in the inner knob, and selecting Audio Setup.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
