Old 11-05-2009, 07:52 PM
petehowell's Avatar
Default 3rd Year Performance #'s
I just signed off the 3rd annual condition inspection on the -9A, and I thought I would re-run some cruise performance #'s to see if she has lost anything. Plus, a meeting was cancelled, and the weather was perfect!
I preflighted, took off, ran on up to 8500ft, and set up for cruise. I locked on the Trutrak and took some 4 way data on the cardinal headings.
22.2" MP, 2270 RPM, LOP 6.0-6.1 GPH, carb heat about 1/4 on.
Here is the data:
NTPS spreadsheet shows 151.6 KTAS with a small std dev. I was happy to find this is just a touch better than my Phase 1 test data. Over 28 smpg at 170+ mph, I guess I'll have to keep her......
Here is the APRS track, the big squares are the test runs:
Pete
Amateur Plane - RV-9A N789PH - 2150+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 11-06-2009, 08:37 AM
Randy Randy is offline
Pete,
Good looking data report, but I would like to know what engine and prop you are using too.
Randy C
RV7A
Old 11-06-2009, 09:14 AM
petehowell's Avatar
Default Hardware
ECI O-320 160HP, Carb, Hartzell, Dual EI
Homebuilt plenum - but I don't think this adds anything
Pete
St. Paul, MN
Old 11-06-2009, 10:08 AM
KevinL's Avatar
KevinL KevinL is offline
Where did you get the spreadsheet?
Old 11-07-2009, 08:59 PM
petehowell's Avatar
Default Spreadsheets
Here you go:
http://www.ntps.edu/images/stories/d...ts/gps-pec.XLS
Pete
St. Paul, MN
Old 11-07-2009, 09:35 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Pete...
You are like... way COOL!!! I love your test data, Thanks!
Reiley
N622DR - Serial #V7A1467 RIP Aircraft Drowned in the 05/2015 Memorial Day Flood
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-08-2009, 12:48 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Inspired
Suitably inspired I ran some tests today and input the data into the NTPS spreadsheet.
TAS as indicated by my temperature and pressure corrected Dynon D100 is consistently reading 5 or 6 kts higher than that calculated from the GPS496 ground speeds.
Anyone know what this means? It implies that the pressure difference between the pitot and static ports is higher than it should be. It's unlikely that the pitot is high so could the static read low if it has a leak?
Jim Sharkey
RV6 - Phase 1
PS - std dev was more like 1 kt instead of the 0.1 kt shown above. Guess I need to fly more accurately
Old 11-09-2009, 09:00 PM
aarvig's Avatar
aarvig aarvig is offline
Default Sweet!
Those are really good looking numbers. The absolute perfect blend of economy and speed! For those of you who have never ridden in Pete's plane it is without a doubt the smoothest running RV I have ever been in. Probably one of the reasons it is so fast and efficient!
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD…but I'll be back
Old 11-26-2010, 02:58 PM
petehowell's Avatar
Default Year 4 Data -- just out of annual....
Looks pretty much the same after 750 hours. Can't complain.... Otto the pilot was flying, and the numbers were pretty steady. Cold -8C , but nice and smooth up at 8000. I think the temps gave me a knot or so....
Here was the track today:
Pete
St. Paul, MN
Old 11-26-2010, 05:34 PM
scard's Avatar
scard scard is offline
Good stuff Pete. Yours has always been at least 7-8kts faster than mine. Although mine has never seen temps anywhere near that cold. But my Otto has buttons to push (gotta be careful which one you push), and a pulse. Thanks for sharing.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2000+hrs. / Cedar Park, TX
