Old 02-07-2019, 12:31 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Walt, just curious why the g3x screens would not share a dimmer with the gtn? It would seem that the three screens would all go together.
Rob Lasater
Rv-14 still workin
Paid nov 2018
Old 02-07-2019, 07:47 AM
kbalch's Avatar
kbalch kbalch is offline
My thought exactly. Iím very curious about the reason for separating them.
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Fuselage in progress)
N114KB (reserved)
Old 02-07-2019, 08:21 AM
Walt's Avatar
Walt Walt is offline
Well the large screen sizes of the G3X/GTN can overwhelm a dark cockpit, so having individual precise control of these 2 major light sources indepently works best for me.
Granted, with enough programming effort, they could work off the same pot, but its much easier IMO to just put in sepertate pots.
Ever try adjusting the lighting curve while actually flying at night... not happening for me.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 02-07-2019, 08:27 AM
kbalch's Avatar
Ah, I see what you mean. Given that my GTN750 screen isn’t that much smaller than the G3X screens, I think I’ll keep them linked to a single dimmer.
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 02-07-2019, 08:55 AM
KeithB KeithB is offline
Ken Balch, yes - that is correct. Using the GAD 27 makes it possible to control separate circuits with a common dimmer. With the GAD 27, each pot provides a reference voltage back to the GAD 27. The 27 then has 2 lighting control circuits off each - one is a "conventional DC voltage of 0-12 volts and the other is a PWM (pulse width modulation) for controlling LEDs. Each has a separate programmed profile. DC circuits are used by the G3X and GTN for lighting control inputs. For LEDs, the GAD 27 is wired on the ground side. So the "panel lights" circuit comes from one switch, then the red glare shield LED, and to the GAD 27 controlled circuit (ground). The "cabin lights" circuit comes from its switch, then the white glare shield LED, and to the same GAD 27 controlled circuit (ground) - so one dimmer, 2 circuits. The method also allows a baggage LED light to be powered off the same switch (cabin) but grounded through a separate switch in the baggage area and not dimmed.
Also,regarding the screens, I have the G3X and GTN 650 on the same circuit and found it easy to balance intensities. Adjusting the brightness is done in the setup (GTNs have an internal profile). Rather than setting it in the air, I did it on the ground in a darkened hangar.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, 24th in the air, >400 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
