Old 02-02-2019, 12:14 AM
Nashman Nashman is offline
Default Newbie question: skin dent
Just starting out on my VS and I made my first (of many I'm sure) goof. Flipped VS-706 upside-down and when I wrapped the skin, the rib created a small but visible dent. I should have known better. I'll probably order a new skin to be safe, but would be helpful to get a second opinion. Am I going overboard or is this going to bother me every time I look at it?
https://static1.squarespace.com/stat...ad?format=500w
Mike
Old 02-02-2019, 12:31 AM
nzrv8's Avatar
nzrv8 nzrv8 is offline
You should be able to gently work that dent out Mike. It looks minor to me. Itís good to set yourself high standards at the start, but mentally prepare yourself for much bigger mistakes as the build progresses
Paid up - Dec 2018
Old 02-02-2019, 04:36 AM
Tom023 Tom023 is online now
Dent? What dent? That is a character line that makes the plane uniquely yours. As Hugh alludes to, youíll know it when you really make a mistake and you will. I have several that have long been forgotten.
RV14A #140083
AW certificate issued
2018 Donation+
Old 02-02-2019, 05:49 AM
Spoon trick. Take a normal table spoon, cover the bottom with oil. Now place your dent over a metal plate, or a bucking bar. With your thumb in the spoon work it over the bump. Typically this will hide most small imperfections.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 02-02-2019, 06:21 AM
Girraf Girraf is offline
Looks like that may have been caused by not tapering the nose of the rib. You won't find that instruction in the plans anywhere but read enough build logs and you'll see that feathering sharp corners on nose ribs where the nose rib flange ends will minimize the chances of that happening.
Agree with previous comments, this is way minor and certainly doesn't warrant replacing the skin.
Sage advice to heed now is whenever you make a mistake, leave the shop and come back tomorrow. Mistakes have a way seeming not so tragic the following day.
RV-7:
Empennage complete!
Wings in progress
Old 02-02-2019, 07:59 AM
kiljoy's Avatar
kiljoy kiljoy is offline
If I had ten dollars for every imperfection I'd caused I'd be able to pay for the plane
Just wait for the rudder!!!
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Somewhere in Ch. 29
YouTube Build Channel
Old 02-02-2019, 08:31 AM
kbalch's Avatar
kbalch kbalch is offline
This is absolutely in the -14 plans; it's explicitly called out in multiple sections.
Ken
RV-8 N118KB (sold)
RV-14A N114KB (#140494)
Finish & FWF kits in progress
Old 02-02-2019, 08:52 AM
Thanks for the words of encouragement.
This, and a night's sleep and I'm realizing that the next step is to bang on the entire structure with a rivet gun -- what could possibly go wrong?
Old 02-02-2019, 03:40 PM
Oh yeah it totally is...my bad. Section 5.2 - Rib Flange Faceting!
I just closed my elevators in the last few days and if I had not given Section 5 another scan (which I do periodically), I would have forgotten the RTV on the trailing edges of the stiffeners. There is no reminder to do that in the section of steps for riveting the elevators shut.
RV-7:
Empennage complete!
Wings in progress
Old 02-04-2019, 12:13 PM
MJarreau MJarreau is offline
Default Hugh is Right
..mentally prepare yourself for much bigger mistakes as the build progresses
My (personal) skin gets thicker every time I have a small success
Mike
DUES REMINDER: DEC 2019
