POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
01-29-2019, 12:20 PM
Antenna wire: amount
I assume that I should probably use the following cable wire for the comm and gps:
RG-400 M17/128 Rf Double Shield Coaxial Cable
How much would I need? A rough guess. 30 ft?
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
01-29-2019, 12:21 PM
Get double plus 25% of what you need .. so when you cut it 1 inch too short you don't have to pay shipping again
Seriously ... don't forget enough to learn how to install the connectors, order extra connectors to train with, and leave enough for service loops in case you have to re-terminate later to troubleshoot.
Progress: Flying!
01-29-2019, 12:29 PM
Depends on what you will use.
At least one com-com antenna under the seats
A transponder antenna in the back
Probably to an IFR GPS antenna on top behind the canopy
a com2?
will you make you own EFIS GPS antenna or buy an antenna with cable
My com antenna cable, IFR GPS Antenna and Transponder antenna cables are probably closer to 50-60 ft in total
01-29-2019, 12:40 PM
Just to add to what Control has suggested, it also depends on where those antenna will be located.
As a reference, my GPS (two of them) antennas are in the wingtip as well as my VOR. The TXPDR and remote radio are behind the baggage compartment and I believe I bought 100' and used majority of it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
01-29-2019, 01:23 PM
well, the transponder antenna cable comes with the empennage kit. It is interesting that that does come with the kit while the comms do not. I have a gtx 45, which has one antenna for both the ADS-B and the transponder. ALso, I think that I have a gps antenna for the EFIS that came with the panel. I wil have to verify.
The VOR antenna will come with a wire. I plan to go with the whiskers in the vertical stabilizer and I can get antenna with the cable.
So it is just the 2 comms under the seat and the GPS on the top of the empennage. Steinair suggested 60'. I was thinking that was overkill.
Ken Stockman
Midland, MI
01-29-2019, 03:53 PM
Does a VOR antenna use coax cable? like:
RAMI AV-532L VOR ANTENNA WITH CABLE
the picture on ACS with cable shows wire ends that don't look like cable terminal.
Ken Stockman
Midland, MI
01-29-2019, 04:30 PM
I bought 60' and used most of it. My VOR antenna (Archer in wingtip) did not come with wire.
01-29-2019, 04:47 PM
Wire
I am building a -10...
G3X touch with XM so:
GPS antenna for GTN 650
GPS antenna for GDL51R
XM antenna for GDL51R
Com 1 antenna
Com 2 antenna
VOR/LOC antenna
Transponder antenna
I asked Steinair, they said buy 100 feet. I did and have used most of it...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
01-29-2019, 05:08 PM
I have the same transponder and used the forward mounting antenna position under the seats. I recall the maximum length of coax is supposed to be about 8 feet. The rear antenna position I understand was for an ADSB IN antenna which is now handled by the single forward one. So I removed the coax to the tail and used for one of the coms. The second Com and IFR GPS on the turtle deck took about 25 feet which I purchased.
RV14A #140083
Down to last 5%.
2018 Donation
01-29-2019, 05:52 PM
I've gone though about 80 ft
A few do over's from cutting cable short, redoing end terminals (buy extra) >
Rv14A
Some of these receiver GPS info via serial connection:
GDU 465 w/XM
GDU 470
GTN 650
GTX 345
GTR 200
G5
Archer ant in wing tip
2 GPS ant on top of empannage
2 bent whip comms on belly
Trnspndr ant on belly
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/2/18 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
