Old 01-28-2019, 10:25 AM
JTJones's Avatar
JTJones JTJones is online now
Default Hmmm
I went through my build photos and believe:
Mystery 1 - Nothing is attached to those nutplates.
Mystery 2 - Those “openings” allow the cover to fit over screw heads. Those screws are used for adel clamps to secure the flap motor wiring harness.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2019 VAF dues paid plus beer money😜
Old 01-28-2019, 11:46 AM
iamtheari iamtheari is offline
Thanks. I get it now. The plans don't seem to show adel clamps but they make sense. And whether it's an adel clamp or a ziptie, having a cut-out to clear them makes sense. I was picturing zipties in the holes in the web of the flap motor channel's aft side (the permanently-riveted-in one), which now that I look at it again wouldn't work without drilling extra holes.
The F-01406B mystery will remain a mystery unless someone else knows why those nutplates are called for. At least I won't feel like the only builder who doesn't know what they're for.
Old 01-28-2019, 11:59 AM
Bavafa Bavafa is offline
I do recall asking for the same thing and was told they are not used. Of course when one gets to my age, the memory will be as good as milk left outside of fridge
BTW, I have mounted my remote TXPDR and Radio on top of that battery angle.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-28-2019, 12:17 PM
JTJones's Avatar
My XPNDR is on the battery angle as well.
Jeffrey T Jones
Old 03-07-2019, 06:41 PM
Debovsky's Avatar
Debovsky Debovsky is offline
Default Replacement of bellcrank mount
Actually, I have substituted the original bellcrank mount (F14139) which bolts on the battery angles with the one installed on the RV-10 (F1035 + F1036) which I will use for a secondary battery rack. It bolts right on. No mods except that the holes left without nutplates do require to be installed then.
I've ordered the following parts from Van's
BATTERY/B.CRANK MOUNT F-1035, $25.00
BATTERY CHANNELS F-1036, $9.10
And these are the pages I have modified into my assembly manual. They come from the RV-10 manual.
Before ordering, I have done some CG calculations to see the effect of installing a 2nd battery behind the luggage compartment bulkhead. The effect is negligible especially if you install a lithium battery.
Marc R. Beauvais
S/N #140070
50% airframe done
C-FOOT (reserved)
2018 due paid
http://www.mykitlog.com/Debovsky/
" Resistance, is futile "
Old 03-07-2019, 07:08 PM
Aha! The mystery is solved! It looks like Van’s used the same lower baggage bulkhead center piece, or a very similar design, between the 10 and 14 and forgot to tell 14 builders that the nut plates in the upper flange of F-01406B are also a vestigial RV-10 thing that we can skip, as we do with the forward holes in the F-1037 battery angles. I can finally sleep!
