Old 01-26-2019, 04:31 PM
1bigdog 1bigdog is offline
Default BC410-H with IO-320-D1A
Has anyone shoehorned in a BC410-H on an IO-320-D1A
without the need for the 45 degree adapter (in other-words using the stock oil filter position). It's very tight but it looks like it might just fit with the alt oriented correctly. I know it will work with the adapter.
Thanks for any feedback and /or images.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 01-26-2019, 05:16 PM
krhea krhea is offline
I have one on an o320d2a, straight or stock oil filter adapter and yep itís tough to get fasteners on but doable.
Keith Rhea RV7
2019 dues paid
Old 01-26-2019, 07:36 PM
RotaVR RotaVR is offline
Default BC 410H
I installed one on my 0-320-D3G with stock oil filter adapter and with proper clocking it fit no problem. Does not interfere with oil filter changes.
I did need to move my firewall mounted oil cooler lower to clear the oil cooler air plenum Scat.
Old 01-27-2019, 08:04 AM
Default thanks
Thanks. I'll order the alt without the adapter and test the fit.
Cheers.
Michael B.
C-FWMB (reserved)
