Old 01-26-2019, 07:19 AM
iamtheari iamtheari is offline
Default Painting behind instrument panel
I'm at the point where the instrument panel frame gets riveted to the fuselage, and I'm debating what to do as far as paint behind it goes. The first bay is of course visible when the canopy is open. I could leave it in primer (smoke gray), paint it interior color (a creamy gray for vintage Ford tractors), or paint it black. How did you do yours, and would you do it the same way a second time?
Old 01-26-2019, 07:29 AM
Tom023 Tom023 is online now
I have a grey interior and I painted it glossy white along with the underside of the canopy that covers those areas. If I had to do it again I would paint it the same color as the interior. It’s time consuming to mask off and inevitably you get some spray through relief cuts, holes and other gaps you may miss during masking. All one color is simple and fast.
RV14A #140083
AW certificate issued, trying to get to first flight!
2018 Donation+
Old 01-26-2019, 07:55 AM
elev666 elev666 is offline
Default White
Iím in the paint it white camp since itís a far brighter area to work in if you ever have to crawl under to there to fix or add any equipment, mind you Iím working on my second slider project, witch are considerably more enclosed!
C-GARV RV 6
1946 C85 J3
RV 7 A project IO-360 -200
Dues paid 01/19
Old 01-27-2019, 06:36 AM
Nova RV Nova RV is offline
Mine is painted same color as interior (grey) for simplicity. Would do same way next time.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 02-06-2019, 02:29 PM
bschweinberg bschweinberg is offline
I primed then painted all of that upper forward fuselage structure black and I like it. Would do it again. The fuselage interior is a different color, I call it a light gray.
Bill Schweinberg
West Chester, OH
N2814X Reserved
RV-14A Started Nov 2013
Builder #140100
Empennage/Tail Cone DONE! (95%)
Wings In Progress (90%)
Fuselage In Progress (75%)
Finish Not Started
http://www.mykitlog.com/bschweinberg (not up-to-date)
=VAF= 2019 Dues Paid
Old 02-06-2019, 04:18 PM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
I primed that area grey, but cover it during normal ops with a panel-to-subpanel velcroed avionics cover. Love the dressed look.
http://www.flightlineinteriors.com/accessories
Abby makes these for the 6, 7, and 9. I bet sheíll work with you on a 14 cover (new product for her).
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King ďBeautiful DollísĒ old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 02-06-2019, 07:26 PM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
Default Instrument Panel Cover
I did ask Abby about an instrument panel cover for the 14 and she said it was not possible due to the demisting fans in the glareshield.
Chad Boot
RV8 Empennage in progress
RV14 140331 VH-VNX. Flying/Sold
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Slider Flying VH-VNZ
Sports Aircraft Assn Australia. Tech Councillor.
2019 Dues Paid
