Old 01-15-2019, 04:45 PM
RV10Man RV10Man is offline
Default aileron bellcrank
What am I missing? The plans show an AN4-32A bolt to mount the bellcrank, but the hole in the bellcrank is 3/8". The holes in the mount are 1/4".
Old 01-15-2019, 04:51 PM
Bushing maybe?
Old 01-15-2019, 04:59 PM
I thought about that too. I haven't studied the plans really close, but I don't see a bushing in the "exploded" views.
YellowJacket RV9 YellowJacket RV9 is offline
Yep, there should be a brass bushing, that per the plans (note 1) "must be 1/64 - 1/32 longer than the steel bellcrank tube. Shorten brass bushing or steel tube as required."
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 01-15-2019, 05:02 PM
They don't show it in the exploded view, I guess it would be hidden inside the bellcrank anyways, but it is called out along with the bolt specs, and also in Note 1, just to the upper right of the exploded drawing, (Dwg 9, Detail B)
Chris
Chris Johnson
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Brass Bushing
See Note #1 on right hand side of DWG. 9. This is called for under the AN4-32 Hardware listed at this location.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 01-15-2019, 05:05 PM
Thanks guys......like I said, I hadn't studied the plans in depth. I guess I just got in a hurry to ask.lol
