Old 01-12-2019, 06:43 PM
jfisher jfisher is offline
Angry Broken Tap in rollbar - UGH!!
Major bummer tonight.
Step 4 of 38-03 calls for tapping 6-32 threads through the rear window into the rollbar. Going well until number 8 when I managed to snap off the tap. RRRR!
Not a happy camper. Been reading lots of google searches, but can't find anything that would work with plexi on top of aluminum.
The tap is broken flush with the top of the plexi about halfway down.
Couldn't find anything in the forums for broken taps. Anybody got any ideas??
I'm stuck.
Jim Fisher
Manchester, IA
RV-14A 140411 Began Jan 2018
Tail kit and QB fuselage done
Finish kit in progress
QB wings coming mid-2019
Thunderbolt 390 ordered
2019 dues paid
Old 01-12-2019, 06:48 PM
ty1295 ty1295 is offline
Can you use a center punch and shatter it/push it thru? I assume hole is thru hole.
Jeff Scott
Proud to have flown with P. Wagstaff and some odd Russian.
RV9A #91247/#91434
Old 01-12-2019, 06:55 PM
rnewcomb7797 rnewcomb7797 is offline
same thing happened to me but the plexiglass cracked too. I had to order new plexiglass and start over. I ground off the broken tap flush with rollbar cause i couldn't remove it. Drilled a new hole next to it. The second time I removed the plexiglass before tapping. That was a hard and expensive lesson learned.
Ron
#140220
RV 14A tail kit done
QB wings in the crate
QB fuselage done
finish kit in progress
Old 01-12-2019, 07:16 PM
scard's Avatar
scard scard is offline
Stop, pause, don't make any sudden moves. It will be there tomorrow and the next day.
From what it sounds like, the tap isn't actually broken off inside what you were tapping. Any such event is definitely time consuming, but this is a little "craftsmanship" test that you can absolutely succeed at.
Noodle it long enough and I assure you that you will be victorious. Sometimes it is even acceptable, as a very last resort, to complete a "fix" by abandoning in place and moving on.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2000+hrs. / Cedar Park, TX
Old 01-12-2019, 07:45 PM
tomkk's Avatar
tomkk tomkk is offline
That happened to me on an RV-12 canopy. I had a small cone shaped grinding tool for my Dremel. I used the tip of that to grind the broken tap down below the upper surface of the Plexiglas. Doing that ended up heating the plexi enough so a helper could actually gently raise the plexi off of the broken tap. I ended up with a hole slightly larger than the others but that wasn't a problem.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 01-12-2019, 07:50 PM
one option, cover hole with RTV and move on. I have one like that. I notice it once in awhile and smile now.
Old 01-12-2019, 08:18 PM
Stockmanreef Stockmanreef is offline
Can you get a very narrow tipped forceps into the slots in the tap and unscrew it out?
https://www.amazon.com/SE-TWSS-C-Pro...ow+tip+forceps
Not sure they are small enough to fit into the tap to do this. Might be worth a try. And for $6 it is worth a try.
just a thought.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 01-12-2019, 08:22 PM
xblueh2o xblueh2o is offline
Is it not possible to get a tap extractor in there? You can get relatively inexpensive sets of extractors.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 01-12-2019, 09:02 PM
jask jask is offline
Tap extractors are not that expensive. Mcmasters. When you tap, always use a quality tap and tapping fluid. When you extract, use tapping fluid and slowly work out and in until it is free. They work well.
RV-7 builder Ramona, CA.
Free prop balancing for Vans owners
(I am not in the business of prop balancing, just as a courtesy to meet other owners.)
Old 01-13-2019, 07:25 AM
BillL BillL is offline
Default Dissolve it,
Dissolve it. Google and see what acids will do this, it will only take a few minutes with the right fluid. Nitric acid is one, household ALUM is another. It will only dissolve high carbon steels, or at least much faster, and no aluminum at all.
Otherwise, leave it or punch it through.
Tap Magic is a good tapping fluid for aluminum, not the best, but more available. That bar is 6061 alloy and softer and more prone to galling. Tap magic is good for drilling that allow as well.
Edit: The ALUM works, but is slow and requires emersion. Not a good candidate, sorry.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
