Old 01-03-2019, 10:43 AM
Selma Selma is offline
Unhappy towbar
.... and a happy new year to anyone out there...
does anyone knows what kind of towbar I should buy? I have to replace the old one (one of the nice guys took mine while my RV9a was parked on the ramp and I couldn't find it anywhere ) The old one looked like a cessna's towbar. Would such a towbar fit to a RV9a?
Pit
flying RV9a
a father & son project
Old 01-03-2019, 10:45 AM
YellowJacket RV9 YellowJacket RV9 is offline
This is the one I use, probably similar to what you had.
https://www.aircraftspruce.com/catal...clickkey=64870
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 01-03-2019, 12:33 PM
mike newall's Avatar
It works, it's economical but the spring isn't strong enough.
If you are wanting something for a longer time, buy a Bogi Bar.
Donated in 2018
Old 01-03-2019, 12:59 PM
N941WR's Avatar
N941WR N941WR is online now
I use that towbar on my taildragger. It came off and my plane rolled into my lawn tractor/tug, bending an elevator (Since re-skinned).
To keep that from happening again, I bent and welded this small piece of bar stock around it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-03-2019, 07:25 PM
Vansconvert Vansconvert is offline
Bogi Bar, absolutely.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 01-03-2019, 07:34 PM
Mine popped off when I was pulling the airplane into the hangar 6 months or a year ago.
My tailbone was bruised, but nobody was around to see it, so my ego remained intact.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-03-2019, 08:00 PM
scard's Avatar
scard scard is offline
Bogi bar in use daily for us.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2000+hrs. / Cedar Park, TX
Old 01-03-2019, 08:54 PM
Problems with the ACS model seem to be related to tailwheel use. I have had no issues with mine coming off, but I use it for steering the nose wheel while pushing or pulling on the prop. I’m sure the bogi bar is great as well, I just haven’t had the need to upgrade.
Chris
Chris Johnson
Old 01-04-2019, 12:21 PM
John Tierney John Tierney is offline
Default WAG Tow Bar
This is what I've been using to move my kit/soon-to be airplane around the hangar. https://www.wagaero.com/ground-suppo...e-tow-bar.html
John Tierney
Salem, WI
RV-7A - Final Assembly
N777JT
Old 01-04-2019, 12:52 PM
Sam Buchanan's Avatar
been here awhile
I've used that towbar (used to be known as a 'Cessna' towbar but looks like it has been rebranded as a "RV" towbar since they are so popular) with the RV-6 since 1999 but am careful about making sure it doesn't pop loose. I like Bill's mod and may do something similar. Because of concern about injury to my personal aging airframe (glad Kyle's wasn't more serious!) I now use a tug to pull the RV-6 back into the hangar with the same towbar.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
