Old 12-31-2018, 07:38 AM
petehowell's Avatar
Default O-320/dual EI/carb/CS prop
Hi Bill,
Your numbers are amazing!
My 9A has been pretty consistent over its 2,100 hours:
High cruise: ~150KTAS @ 7500ft on ~6GPH (burns a little less at 12,500)
Low cruise: ~130KTAS at any altitude on ~5GPH
Loiter: stays in the air at ~3.5GPH, but is not in a hurry to get anywhere - good stetting for getting photos.
I'll get my yearly performance numbers to post in the next week or so.
With mogas after discounts and rebates in the $2.25 range now, low cost(for aviation) fun is possible!!!
Happy New Year!
Pete
Amateur Plane - RV-9A N789PH - 2100+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 12-31-2018, 08:41 AM
hydroguy2's Avatar
hydroguy2 hydroguy2 is offline
Originally Posted by N941WR View Post
My O-360 powered -9 taildragger spinning a fixed pitch Catto prop will cruise right at 175 knots at 8,000 feet density altitude at 75% power....
Hey Bill, what is the fuel burn for this 175kts & 75%....just curious
It's just one Dam job after another
Brian, N155BKsold
Old 12-31-2018, 09:59 AM
Kitplane Crafters Kitplane Crafters is offline
Default RV-9A with O-235 Engine Performance
Originally Posted by SpeedyMedina View Post
Thanks for the quick response!! yes I see that one from Vans, but I was looking to some one that did it to see his opinion.! I see you use to have an RV-10, do you mind to tell me your opinion about that plane?
Thanks you again!
Eddy
I built an RV-9A with the Lycoming O-235-L2C 118 HP, and it does meet Van's numbers. It is N942WG.
I also don't totally believe it hurts resale value too much, as there are always people out there trying to get the best bang for their buck. An RV-9A or RV-9 with that engine is getting pretty good gas mileage and still has a respectable cruise!
Todd Wiechman
Old 12-31-2018, 04:27 PM
N941WR's Avatar
N941WR N941WR is offline
Brian, it is drinking fuel at that setting, almost 13 GPH at 100 RoP. With only 36 gallons on board, I typically fly it at between 150 and 160 knots. That works out to around 50% to 55% power and ~7.2 GPH. The numbers go up and down depending on the conditions and I never really worry about it too much. My typical flight sees me level off, pull back to 65% power, let it stabilize. If I'm above 6500', then I will go LoP, which drops me to 50 to 55% power, as I said.
The -9 is surprisingly fast. A couple of the local RV-7 guys and I did some formation work together and even with the fixed pitch Catto, they were stunned that all in, a lowly -9 could out run them. Even more surprising was that at some speeds, I could outclimb those with a CS prop. That wing is just amazing!
Rob and I need to go side-by-side to see who's is faster.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-31-2018, 09:26 PM
My -9A does about 155-157 KTAS at 7.5 gph, WOT & LOP at a DA 0f 9000' to 10,000'.
Stock 160-hp IO-320-D1A w/ Slick magnetos, FP Catto 70x70 2-blade prop, with a TOW of about 1500 lb.
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2019
Old 01-01-2019, 12:24 AM
hydroguy2's Avatar
I have a pretty good idea how that'll end....but could be wrong.
My normal flight plan was 175kts @ 8.5gph above 8500', I usually beat those numbers chock to chock.
If I ran at peak, speed was over 180+kts burning 9.5-10gph.
Full power was 188-190kts
Brian, N155BKsold
Old 01-01-2019, 07:48 AM
N941WR's Avatar
Sounds like I'll get dusted!
I spoke to Rob the other day. He is still very impressed with your-7.
Bill R.
SC86 - Easley, SC
Old 01-01-2019, 11:06 AM
db1yg's Avatar
db1yg db1yg is offline
Default RV9(a) Performance
Hi Bill,
I would agree with you that the RV9 wing performs incredibly well at all altitudes but excels from 10k up into the mid teens--even though power is going down at the higher altitudes that wing just does not want to give up speed.
I have no hard take off numbers but I do have a lot of data that I collected on climb and cruise while I was testing some of Craig's propellers.
My 9a does have a James cowl/plenum, a lot of detail clean up, and is powered by a stock compression parallel valve IO360/180 hp engine. My typical cruise with the fp 3 blade Catto was 63-65% power, lop (7.8 to 8 gph) which at 8 to 10k ft density gave me from 163 to 165 ktas. Several years ago while testing Craigs gen 3 carbon fiber 3 blade I ran some tests at wot (2660 rpm-prop was slightly over pitched for my plane) and saw a couple of ticks over 178 ktas at 9k density. The mixture was set at 125 to 150 degrees rop for that run. I have since converted to a WW RV200 constant speed propeller but have yet to run it at high rpm/high power. My current typical cruise with the WW is 2350 rpm, wot, lop (7.8-8 gph) and I see 165-168 ktas.
Been loving this RV9a-360 combo since 2006!
Happy New Year to all and of course,
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 01-29-2019, 04:18 PM
What kind of kts cruising speeds are you observing with this low HP engine, and GPH consumption?
Also, is it a major PIA to adjust the solid lifter valves every 100 hrs, or at least inspect them? Full cowl removal for access?
Old 02-04-2019, 12:51 PM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Pretty similar to mine
My -9A, 160hp O-320 and a CS prop, gets about 158KTAS at 7000-8000, wide open, and about 7.7 gph, TOW maybe 1550.
N929JA, 2007 RV-9A
Based W96 - near Richmond, VA USA
2019 Dues Paid
