Old 12-25-2018, 11:54 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default JD Air Parts Canopy Latch on -14?
https://www.jdair.com/custom-tip-up-...v-6-rv-7-rv-9/
Have any -14 builders considered this alternative?
The original plans designed latch on my -9 tip up has served me well but I do like the flush finish.
Thoughts?
RV-9A; IO-320 w/ Whirlwind WW-151
(Flying since June 2011)
RV-14A; tailkit
2019 =VAF= donor
Old 12-25-2018, 03:03 PM
control control is offline
This or something similar will definitely go into my 14 at some point. But for now I focus on getting it in the air!
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 12-25-2018, 09:13 PM
jdmrv7a jdmrv7a is offline
Default JDAir Latch for RV 14
I purchased the JDair latch for my RV14-A Quickbuild and have not installed it yet. The supplied drawing does not match the RV14 rivet pattern around the latch. I think the drawing is for a prior Van's model. When I measured the slot for the JDair latch the dimensions appear leave a forward fuselage rivet cut in half. I requested a RV14 drawing from JDair, don't think they have one.
If any RV 14 builders have installed this latch on a RV14 QB I would greatly appreciate a scale drawing or template of the existing rivet pattern and required slot for the latch.
RV14-A QB, Flying after 1200 build hours
New Lycoming IO390 X, HZ CS 2 Blade,
Garmin Dual G3X 460, GTN 625, A/P 507,
GTR 200 and 20, 245 audio, GTX 45R and more.
Repairman Certificate
Last 20 years: Commander 114 & PA28
Old 12-26-2018, 11:23 AM
mturnerb mturnerb is offline
Looking at the online drawing the part looks much different (wider) than the original. Seems to me it would take quite a bit of alteration to make it fit especially if the original has already been installed. I'm thinking if I want to add a lock I'll drill a hole in the tab on the latch and use a padlock.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 12-26-2018, 11:59 AM
iamtheari iamtheari is offline
Two questions. First, how do you open the canopy from the outside? Second, what is the real advantage? I'm all for upgrades to my RV-14, but I'm not sure from what I see of this latch that it is a meaningful improvement.
Old 12-26-2018, 12:41 PM
Erimo's Avatar
Erimo Erimo is offline
I installed it on my RV14 QB. It requested some arrangements due to Van's latch already installed on QB. I had to well position the cutting and holes, but I love the final result.
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 12-26-2018, 02:50 PM
You get a solution that looks way better, like they say on JDAIR: "With this latch there are no parts extruding from the aircraft skin, it's a flush mount system. Simply push in on the forward part of the latch to release the main latch handle."
RV-14 kit #140138
Old 12-26-2018, 03:25 PM
MED MED is offline
I appears you did not install the key lock portion of the latch, or maybe not yet. How will you lock the canopy without it?
MED
140236
N435MD
Old 12-26-2018, 04:36 PM
The part that protrudes from the skin with the stock setup is pretty minimal, isn't it?
Old 12-26-2018, 05:26 PM
Eric,
Is the template that is taped to your fuselage a 1:1 scale drawing? If so, can you post a .pdf copy so I can review. Many Thanks for the pics.
