Old 06-30-2018, 03:02 PM
kbalch's Avatar
kbalch kbalch is offline
Default Elevator riveting question...
I've been motoring along pretty well and making good progress nearly every day. One task today, however, has seen me talking to myself out in the garage as I tried to figure it out.
On page 09-18 Step 5, how the heck is one meant to buck those rivets along the rear spar?!? I have the special bucking bar, but that's intended to utilize leverage (when doing the second skin) unavailable with the assembly clamped to the edge of the workbench for this step per the plans. None of my many other bucking bars fit suitably inside the rear spar. Is it a two-person job with the special bar? It'll take two hands on that bar and I'm short a third hand to run the rivet gun...
What am I missing?
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Fuselage in progress)
N114KB (reserved)
Old 06-30-2018, 04:17 PM
Reflex Reflex is offline
Not sure if the pictures below are going to answer your questions, but maybe they'll help. I clamped the skeleton down firmly and that left me two hands to rivet. Used a standard tungsten bar. It's been a while, but I don't recall having a clearance issue.
The straight edge you see in the first picture is made from 1" angle with a 2" flat riveted to one side. Used double flush rivets so it would sit flat.
Used this bucking bar: http://www.cleavelandtool.com/Tungst...uctinfo/BBT41/
Dues Paid for 2019
RV-14
Empennage Complete
Getting Ready to Close Wings
Old 06-30-2018, 06:09 PM
kbalch's Avatar
Thanks! I have it clamped down firmly, but the only bucking bar I have small enough to get in there just isn't very substantial. I think that tungsten bar is the way to go. I'll order it on Monday, though the holiday next week will delay delivery. Maybe I'll get started on the tailcone while I wait...
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 06-30-2018, 08:35 PM
DaveO DaveO is offline
Are you aware that there is a special bucking bar that is to be used in your building of the empennage? Look for it at Cleveland tools marked as a tool for the RV -10. You need it for your build also. It cost about 40.00.
I think it is used for the elevator with the trim tab, and maybe the other too. Can't remember now.
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-30-2018, 08:50 PM
kbalch's Avatar
Yes. As I said, I have that special bucking bar, but it’s meant to aid with the second skin, not the first. I’ll see tomorrow if I can somehow make it work and, if not, will order the little tungsten bar on Monday.
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 06-30-2018, 10:26 PM
Ok, I built both elevators myself with no help, so I am not sure exactly what you are referring. Sorry if I spoke out of turn.
RV-7A N1243A Sold
Old 07-01-2018, 01:11 AM
RV-14E's Avatar
RV-14E RV-14E is offline
You can reach that elevator rear spar by hanging the edge over the work table and reaching up with a bucking bar. It's possible solo. I did it with help:
http://rv-14a.blogspot.com/2014/02/e...ront-spar.html
Using a tungsten bucking bar makes it easy. There are several available. For the elevator rear spar, I used this one:
https://www.yardstore.com/riveting/b...gsten-1-66-lbs
At the bottom of this page, you can see a smaller one that I later used for tighter spaces. It would also work for the elevator rear spar.
http://rv-14a.blogspot.com/2015/09/f...gage-area.html
The special bucking bar, outlined on page 09-17, is used at a different stage, on page 09-20. It is used when you put the second skin on the elevator (since you can't reach into the C-channel of the spar with both skins on).
For most of those rivets, I used the special bucking bar with help: http://rv-14a.blogspot.com/2014/02/e...ront-spar.html
For the few rivets along the spar that the plans have you buck later, I figured out one way to do it solo: http://rv-14a.blogspot.com/2014/06/e...rear-spar.html
Old 07-01-2018, 09:02 AM
kbalch's Avatar
Thanks for the links and confirmation that the little tungsten bar is the way to go. Yardstore is a new one for me and a great find. I've just ordered the bar from them.
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 07-05-2018, 06:59 PM
bk1bennett's Avatar
bk1bennett bk1bennett is offline
For me the section with the trim tab hinge was the hardest. Used a steel bucking bar and got acceptable results, but they are the ugliest rivets I have bucked so far. You have to buck by feel. I also made a couple of smilies in the skin. Not happy about it but it will suffice. Not going to redo the skins because of it
Latest Annual Donation Date: 11 Apr 2018
RV-14A Empennage Kit #140396
Old 02-10-2019, 05:11 PM
mjanduda's Avatar
mjanduda mjanduda is offline
Do you really need this special bucking bar for riveting the second skin or can you use the tungsten bar for this also?
EDIT: Just ordered a piece of steel for a few bucks. It's quite narrow near the trailing edge and I'm a bit fearing for my fingers.
