Old 06-21-2017, 12:53 AM
bruceh's Avatar
bruceh bruceh is offline
Originally Posted by BruceP View Post
So, do you have a Skyview, and if so, do you remember how you configured your flaps?
Yes, I have a Skyview EFIS. The VP-X configurator is what is used to set the range and the various stop positions for the flaps. You can also reverse the polarity of the flap motor voltage, so no worries about which wire is up/down.
I think the only thing required on the Skyview is to go into the EMS configuration and select that the flap position is coming from the VP-X data. Then configure a widget on the screen layout editor display to be tied to the flap position input. I have a different widget for the various screen partition sizes. On the full EMS screen, it is a quarter circle shape with a flap like pointer and on the narrow screen I just have degree numbers.
I'm pretty sure the set up is well documented in the Skyview Installation Guide.
See page 13-5.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2019 VAF donator
EAA Tech Counselor
Old 06-22-2017, 11:05 PM
BruceP BruceP is offline
See page 13-5.
Ok, thanks! Maybe I'll give it another try.
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 11/18
Old 06-23-2017, 05:30 AM
BillL BillL is offline
I used the Ray Allen POS-12 sensor and mounted it like this:
Flaps up position - sensor arm fully out:
For those choosing to use the sensor, the angle to the vertical is 30 degrees. I did a drawing to determine the ideal.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 06-23-2017, 08:45 AM
Bavafa Bavafa is offline
Nice set up here. Mine is similar only the sensor bracket has a pivot point, though from fully up to fully down there is very little movement. It has worked flawlessly with no maintenance required in 600+ hours. Each annual I look at for any sign of issues as I inspect the flap motor and attachment points.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 06-23-2017, 07:03 PM
Closterman's Avatar
Closterman Closterman is offline
Default Flap position sensor
I put my sensor on the side of the fuselage instead of the center column. Like that, you can remove center section without remove the sensor. Work great and never had any trouble. On the pics, the link are disconnected because I work on it when I take the pics.....
http://www.mykitlog.com/users/displa...=205258&row=11
Martin "Closterman" Rousseau
www.mraerodesign.com
Piper Cherokee C-FEYI (sold)
RV-7A C-GMYL Status : FLYING with perpetual RV Grin!!!
RV-9A Status : Tail & Wing 90% Fuselage: 10%
Hatz Classic : building wings (on hold)
http://www.mykitlog.com/Closterman/
Donated to VAF (12-2017)
Old 06-28-2017, 11:41 AM
Shawn25854 Shawn25854 is offline
I have a question, why doesn't anyone use the Motion Systems actuator with built in feedback?
Motion Systems makes the exact same series actuator for every RV model WITH built in feedback. No need to mount up extra brackets and sensors. It's all done for you on the inside with a FAR superior pot than what's inside the POS-12.
It wires up just the same as the actuator with the external POS-12. Just seems like more work and more to go wrong with all that extra linkage as Walt pointed out.
If you really want flap position why not use the same motor with all this external stuff built in?
What if it breaks you ask? It'll last a lot longer and give you a much cleaner signal than the POS-12, trust me. If you put both the built in pot inside the actuator and the POS-12 pot on a scope you can visually see how superior the pot is inside the actuator compared to the POS-12.
I built my own digital flap controller and use the motor with built in feedback. No other hardware and brackets to mount.
No quite as simple as looking over your shoulder but a lot easier than mounting up all that ancillary stuff just to get flap position.
As stated earlier, my post is simply an expression of my OPINION and should be taken for what it's worth.
Old 06-28-2017, 11:59 AM
Walt's Avatar
Walt Walt is offline
Sounds like a much better solution, you got a PN for that motor Shawn?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-28-2017, 12:48 PM
Hi Walt,
It's very easy, just add "-POT" to the end of your current 85615 series part number for your RV model specific actuator. Not all RV models use the same actuator so your mileage will vary.
Note: as the stroke length on the actuators increases the center to center mounting distance on the holes MAY increase just a little. This means that the minimum retracted centerline distance might be slightly longer than the non feedback version. This is for the cover on the feedback pot. This is more noticeable only on the longer stroke models.
You can check this on the Motion Systems website.
Shawn
Old 01-11-2019, 10:31 AM
sblack sblack is offline
Originally Posted by Walt View Post
So when you have an electronic flight control, rigging now becomes critical and surface position is now dependant on an "inexpensive" position sensor with somewhat questionalble repeatability. .
I agree with that, which is why I am only using the sensor for a cockpit indication. If it breaks I can look over the side to verify. The motion of the flap motor will be completely independent of the sensor. It is a bell and whistle that is not strictly required, but it is easy to do and cheap and my EFIS has the capability so for the sensor cost and $5 of wire I will have the flap and pitch trim displayed.
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2019
Old 01-11-2019, 04:32 PM
Wunderon's Avatar
Wunderon Wunderon is offline
Not having done it, is it easy to see the flaps at night?
Dave Grimmer
RV8 “final” assembly lol
Edmonds WA
paid 2018
