Old 02-06-2019, 07:44 PM
FNG FNG is offline
Default RPM on takeoff
I just bought a RV-9A. It has an O-320 A2B and three bladed Cato FP prop.
The rpm at 55 knots on takeoff roll is only 2150RPM AT 10*C and 1200 pressure altitude. Is this normal? Iím not certain it is developing full power.
Thanks.
Old 02-06-2019, 09:02 PM
Michael Burbidge Michael Burbidge is offline
Thatís about my Static RPM. Full throttle, brakes holding the plane in place. But I have a 160 HP O320.
Michael Burbidge
Sammamish, WA
RV-9A FlyingĖ320 hours so far!
Last Donation: December 2018
Old 02-06-2019, 09:08 PM
lr172 lr172 is offline
I would expect someting in the neighborhood of 2150 RPM static, but would expect it to be a bit higher at 55 knots. If you cruising at 8000' what is the max RPM WOT and ROP?
N64LR
RV-10 in progress
Old 02-06-2019, 09:34 PM
PCHunt PCHunt is offline
I'm sure Larry meant to specify 8,000' DENSITY ALTITUDE.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2019 Donation+, Gladly Sent
Old 02-06-2019, 11:53 PM
control control is offline
Fixed pitch is always a compromise. If your take-off performance is good enough then I would not change anything.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
