Go Back   VAF Forums > Model Specific > RV-9/9A
Old 01-30-2016, 09:49 AM
scrockard scrockard is offline
Default slider block drilling - C-677 jig idea
Here is an interesting jig idea that I created. This jig worked like a charm and it didn't take too long to create.
I was pretty sure that my hand drilling wouldn't work for drilling those white anchor blocks on the slider. I needed 23 degrees on one axis and 5 degrees on a different axis. With this jig, I was able to do a straight down drill into the UHMW plastic.
This was 3-D printed in PLA plastic. The flat base ends were used to clamp to the drill press before drilling. I just hand held the UHMW plastic into the snug fit of the jig while drilling. I used TurboCad for the jig design.
Note: the left and rights sides have different angles and therefore require a different jig.
RV-9A - Oregon City, OR
flying since June 30,2018
2019 Dues paid
Old 02-08-2016, 07:47 PM
gladiator68 gladiator68 is offline
Default Nice tool!
Hi,
That is an awesome tool to make a tough angle!
Let me know if you'd be willing to loan. I'd pay shipping!
Thanks!
Rick Glatthaar
Olympia, WA
RV-9
Tail done, wings done,
Fuselage "almost" complete, working on wiring/panel
Double dues paid for 2018.... Thanks Doug!!
Old 02-08-2016, 08:17 PM
wjb's Avatar
wjb wjb is offline
V-E-R-Y cool! What a great, creative solution! I love it!
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 02-09-2016, 07:31 AM
Originally Posted by gladiator68 View Post
Hi,
Thanks!
That jig is already loaned out to a fellow builder!
I'll see if I can print up a couple more. Send me a private email through this forum and I'll get your address. It might be a couple of days before I can print another one...
2019 Dues paid
Old 01-23-2019, 09:03 PM
LynolA LynolA is offline
This is a great idea to drill the C-677 UHMW sliding canopy rear anchor block. Can you provide a link to the 3D print file (STL/OBJ/AMF/3MF/PRUSA)?
Thanks!
Lynol
1946 Ercoupe Flyer, N2169H
RV7A Slider builder- Finish Kit in work
Old 01-27-2019, 11:57 AM
sure - here is a link to my website where I zipped up this old design (2016 vintage).
The original turbocad source is in there along with stl files and even gcode (which is specific to a MakerGear M2).
What I learned:
I used these jigs and yet I found my canopy to be tight to the point where I've had to push up on the rear of the canopy to release it after unlocking the latch in front. If you find this to be the case, address it! Not all canopies have the same geometry and it doesn't take much to make a big difference in behavior. Try to look at the rub spots as it engages and see where things line up and then address them systematically. You could find one side fitting better than the other...
Putting a chamfer on the outside rim of the hole (per directions), lubricating the rail pin, even a slightly oversized hole if all else fails.... OR get a new block and drill a new one...
Good luck.
Scott
2019 Dues paid
