wickedsprint
So I used to think I really wanted to build an 8, but now..I think I might actually like the 4 a bit better...especially if they might perform better given comparable engines. I also really like the idea that it is more builder intensive, so if something gets dorked up in the hangar, I am more than capable of fixing it. I also really like the way they look, but I also love the 8.
Mission...90% solo vrfr flying..with a passenger on occassion, but I'd definitely want to be able to do mild acro with one, probably a weight limitation dictates this. People also worry about the size..but at 5'10 and 165lbs...I don't forsee a problem.
Concerns...setting up a jig perfectly and ending up with a straight airplane
Landing gear/engine mount combo...this is weird to me..and I understand the 8 might be the only one without this..but I rather like the 8's landing gear in that it seems to be more conventional.(pun?)
Is this even an issue worth wondering about? I mean every other acrobatic RV(to include the first one) uses the combo mount that I am aware of, so it must be ok.
The cost savings of an RV4 vs 8 seem pretty signifigant, almost makes the prop free.
I'm thinking a 180hp Para valve with the BA composite prop on either airplane...day VFR only...with light weight on everything else being ultimate goal...so likely a very simple single screen glass setup with a 496 form factor style garmin.
