Old 06-10-2019, 05:03 PM
edward7048 edward7048 is offline
Default changing carb. floats
What is the best way to change the floats in the bing carb. on the RV-12?
Old 06-10-2019, 07:23 PM
Driftdown Driftdown is offline
Swing the bail out of the way and drop the bowls.
Old 06-10-2019, 07:52 PM
tomkk's Avatar
tomkk tomkk is offline
I have to slide the carb throat out of the rubber sleeve to make room to drop the bowl. Loosen the clamp around the rubber sleeve, rotate the carb a bit to break it loose from the rubber and slide it out. That gives me enough room to swing the bail out of the way and drop the bowl.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 650 hrs as of 09/2019
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK in progress
Old 06-10-2019, 08:12 PM
Initially I was very reluctant to mess with my carburetors and figured if it ainít broke donít fix it. Eventually I started opening them up to check for debris and look at the floats. I found them to be pretty robust and resistant to most beginner mistakes. I would suggest going to one of the ROTAX courses and get the instructor to pull one apart. Itís not really part of the service or line maintenance courses (appliances are part of the Heavy Maintenance Course), but most instructors will take a few minutes to open one up and dispel the mystery.
Old 06-10-2019, 08:14 PM
DHeal DHeal is offline
You might find it advantageous to remove the air filter on the right-side to provide sufficient room to pull the carb out of its socket. The left-side carb can be removed from its socket with its air filter in place. Be careful when removing the bowls as there may be some residual bowl fuel splashing about.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 830+ hours (as of Oct 2019)!
VAF donation through June 2020.
