Old 06-04-2019, 09:54 AM
Jyuma Jyuma is offline
Default Rotax 912is vs. 915is
This may be a dumb question but can you replace the 912is in an RV-12 with a Rotax 915is after certification? Any obstacles that cannot be overcome?
Or maybe better yet... can you modify a 912is to produce similar performance to the 915is?
Old 06-04-2019, 07:48 PM
Isaac's Avatar
Isaac Isaac is offline
Default 912iS with 915is Performance
Very doable, Edge Performance in Norway has the solution you are looking for.
Upgrading the 912iS to equivalent performance of a 915iS would probably be much simpler than converting the entire firewall forward to a 915iS.
https://shop.edgeperformance.no/no/
https://www.facebook.com/edgeperformance.no/
http://badasspowersports.com/
___________
James
RV6 N947J
