Old 06-03-2019, 02:50 PM
E. D. Eliot E. D. Eliot is offline
Default 912 - Gaskets, etc - What do I need?
Hoping to move my 12 parts to a hanger for assembly soon. I need to know which gaskets I need to have on hand in order to properly service my 912ULS during the first 50 hours or so. Thanks in advance.
Building finally
Old 06-03-2019, 03:16 PM
DHeal DHeal is online now
I suggest that you become very familiar with the Operator's Manual, Line Maintenance Manual, and Heavy Maintenance Manual for your ROTAX 912 ULS (https://www.rotax-owner.com/en/suppo...series-engines). Your first 25-hour inspection/maintenance task is critical and must be accomplished and documented in accordance with ROTAX's requirements if you are to maintain your engine warranty.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 830+ hours (as of Oct 2019)!
VAF donation through June 2020.
Old 06-03-2019, 08:12 PM
I maintain a couple of extra carburetor bowl gaskets, copper gaskets for the oil drain and magnetic plug and a couple of O-rings for the intake manifold.
Old 06-04-2019, 03:22 AM
The magnetic plug on the 912 gearbox does not use a gasket.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 511
LSRM-A Certificate 2016
Old 06-04-2019, 08:08 PM
Yep, Mike, I misidentified the locking pin plug.
I keep a lot of stuff in the hangar just in case, like an extra set of plugs. I mentioned the stuff I routinely need.
