Old 05-30-2019, 11:33 AM
pilotyoung pilotyoung is offline
Default Challenger Lifetime Oil Filter
Is anyone using the Challenger Lifetime Oil Filter on their Rotax 912? Of so, how do you like it? Pro's and Con's.
Thanks.
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 140 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 05-31-2019, 07:45 AM
rongawer rongawer is offline
The short answer is yes. However, the longer one is that Challenger oil filters are made by K&P Engineering as the PMA manufacturer for Challenger and can be bought online as a non-PMA part here https://usaoilfilters.com/. I don’t want to take business away from Challenger, but if you’re not in need of a PMA part, such as on an experimental airplane, then non-PMA parts make a lot of sense (same part, no 8130 cert)
I have these on my car, truck and airplane.
Advantages are: higher flow rates, better filtration, no more buying or disposing of filters and additional oil cooing. Oh, and probably a “cool factor”. The only disadvantage is the initial price; depending how often you are changing your oil, the payback period is not too long.
K&P makes very high quality parts, and a good small company with great service.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 06-01-2019, 09:33 AM
Default Filter specs
A couple folks have asked me which K&P filter works on the Rotax, so I thought I’d post my responses here for reference.
Looking at Rotax’s black filter specs, ¾”-16 thread, 2 5/8" diameter seat and 1.1 bar relief valve, the K&P S4 would be a correct replacement (also a direct replacement for the KN HP/PS/SS-1002 filter line, if you’re using those). You should measure your actual filter to verify as I simply found the Rotax filter spec online and don’t have a physical reference. I have a UL Power engine, not a Rotax, which uses the S1 filter.
The S15 filter is the same spec at the S4 with the exception that it is a little taller for a slightly larger volume and added cooling fins if you have the room to fit it.
They also have a C4 housing with a 1” nut and safety wire holes machined in if you’re inclined to have that. You can email or call the fine folks at K&P and they’ll be happy to help and mix n match parts to fit your needs. Do be sure to mention that it is for an experimental airplane as they have an obligation to send you to Challenger for certified aircraft parts.
Ron Gawer
Old 06-01-2019, 09:41 AM
I'm curious how you clean the screen and not contaminate the the clean side of the filter?
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 441
LSRM-A Certificate 2016
and MJ Stricker (CFI) - 1st Lt. Captain B-17H
Old 06-01-2019, 09:45 AM
They have some videos on their website that go into the design of the filter, as well as demonstrate the maintenance of the filter. http://kandpengineering.com/press-area/
I’m sure they’d be happy to answer any questions you may still have.
disclaimer: I have no relationship with these folks, I just like their products.
Ron Gawer
Old 06-10-2019, 03:28 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Default replacement for Tempest 48108-2 filter
Maybe this should go in a different thread, but for those folks with Lycoming engines or their clones and using the common Tempest 48108-2 filters, the guy I talked with at K&A says you should order their C4 housing with an S15 filter (see the K&A website for photos). With free shipping and no tax, at least for me in California, total will be $169. Not too bad really given that the Tempest filters are $20.50 each plus shipping from Spruce. K&A claims better oil flow through their product, so might be worth a try.
erich
Old 06-10-2019, 04:04 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I have a couple of certified customers that have them installed. They're super easy to clean and inspect. Really like them.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
