Old 05-22-2019, 11:50 AM
HansLab HansLab is offline
Default coolant spring
All,
How in the world did you guys inserted the spring into the coolant hose? I am thinking about searching a smaller diameter. Unless one of you lets me see the light. And don't point out the manual / plier thing: that didn't work after 3 cm.
Hans Labruyere
build & sold project Kitfox IV
Bought project & building RV12 #120742
Old 05-22-2019, 12:17 PM
Originally Posted by HansLab View Post
All,
Are you certain you were trying to rotate the spring in the proper direction?
When rotated the proper way, the spring will naturally get smaller in diameter and get be pushed through the hose while it is being turned.
Scott McDaniels
Hubbard, Oregon
Old 05-22-2019, 01:39 PM
Yep, I'm sure. The spring thread is quite thick, it's diameter hardly gets smaller. Couldn't get it any further than some 2"
thanks for your quick reaction!
Hans Labruyere
Old 05-22-2019, 02:03 PM
Without raising eyebrows... how about trying some lubricant? Perhaps soapy water solution and rinse once spring is fully inserted.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 441
LSRM-A Certificate 2016
and MJ Stricker (CFI) - 1st Lt. Captain B-17H
Old 05-22-2019, 02:47 PM
Vakashi Vakashi is offline
I just heated the pipes with hot water out of the hot water tap and they went in by hand with no pliers and no twisting. The water also acted as a lubricant.
Old 05-23-2019, 08:55 PM
I used dishwasher soap and flushed the line afterward.
Old 05-24-2019, 07:38 PM
DHeal DHeal is offline
Slightly bend inward the leading point of the spring so it doesn't dig into the tubing wall as the spring is rotated.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 770+ hours (as of May 2019)!
VAF donation through June 2019.
Old 05-24-2019, 09:00 PM
DaleB's Avatar
DaleB DaleB is offline
Might help, but if the point digs in, you're turning it the wrong way...
Dale
Omaha, NE
Previous RV-7 project (sold)
