Go Back   VAF Forums > Main > Safety
Old 05-20-2019, 05:35 AM
AirHound AirHound is offline
Default Carbon Monoxide Detection
Anyone using a sensitive electronic monitoring device have any suggestions on a best one? Thank You!
Doug
Old 05-20-2019, 06:44 AM
catmandu's Avatar
catmandu catmandu is offline
I did some reasearch and best bang for the buck I could find was a Sensorcon. “Aircraft2017” 20% discount code seems to be still active.
Mike C.
Maryland's Eastern Shore
RV-6A bought flying
Old 05-20-2019, 07:28 AM
TShort TShort is offline
I put one of these in the -10:
http://www.fdatasystems.com/gd-40-co-detector/
I get alerts, and a readout in ppm (pretty sure those are the units) on the display of the G3X. Very happy with it.
The business owner is on the forums and is an RV guy.
Thomas Short
KUMP - Indianapolis, IN
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 05-20-2019, 07:31 AM
bkervaski's Avatar
bkervaski bkervaski is online now
Just about everyone at our field uses this one ...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-20-2019, 08:07 AM
Another vote for the Flight Data System unit--------when I was looking for a detector for the RV10, I found out that these units need a replacement sensor periodically------the FDS was the longest lasting and the cheapest to replace.
Old 05-20-2019, 10:19 AM
rongawer rongawer is offline
That's the one I have. Works great. I have found it lasts about 6 months on a battery if I leave it on continuously.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 05-20-2019, 11:27 AM
Default CO Detection
Thank you for the choices, I’d rather pick one of them than rely on the stick-on, color changing type.
Will any of them show trends? For example ppm changes which can be used to analyze cabin leakage during different phases of flight. Or, are they basically just real-time readouts and peak numbers-which work too?
Any common/unique CO activity associated with ELSA RV12’s in general? Or, expect 0 ppm if built to (ELSA) KAI specs?
Thank You
Doug in IL
Doug
Old 05-20-2019, 11:46 AM
Mine is connected to the G3X, I have an ongoing display of CO levels, and alerts above a certain level. I also installed the LED next to the test button on the panel.
The data stream is recorded in the G3X logs, and available for review in the data set (i.e. on download to savvyanalysis.com etc)
I really like the unit, have been very happy with it.
Thomas Short
Old 05-20-2019, 03:58 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Thumbs up This is the bomb
https://aithreaviation.com/products/aithre-shield-ex
Connects to Dynon SkyView, Garmin G3X and Advanced Flight Avionics. They can log the data.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 05-20-2019, 07:52 PM
drtgraves drtgraves is offline
No one mentioned guardian avionics. I bought one at sun n fun but haven’t installed yet. Feedback?
EyeDoc
14-499 221RV reserved
Paid
