Old 05-17-2019, 06:16 PM
EastCoastFlyer EastCoastFlyer is offline
Default Glareshield finish
Im in the process of putting in the optional glareshield. Does anybody have any cool ideas on what to paint it with and/or how to finish the aft edge?
Old 05-17-2019, 07:22 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
I bought the edge from McMaster Carr
The carpet is from Flightlines Interior
I also painted the underside the same as my interior
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2019 donation current
Old 05-17-2019, 07:27 PM
rjtjrt rjtjrt is offline
I have not fitted the glareshield yet.
Not sure if it is an advantage over standard non glareshield panel.
Old 05-17-2019, 10:57 PM
lr172 lr172 is offline
You want a flat finish paint to avoid glare. I did the 6 with rattle can flat black. While it looks good, the paint burnishes very easy with any rubbing. I learned a trick for my 10. I used SPI black epoxy primer. Put first coat on as normal. For the second coat, I thinned it 50% with reducer. This leaves something between flat and egg shell finish that is tough as nails and won't burnish.
I got some thin and small rubber edge material from Mcmaster Carr for 1/32" material and it holds nicely and looks good.
N64LR
RV-10 in progress
Old 05-18-2019, 07:49 AM
rongawer rongawer is offline
I painted mine flat black and then bought some 5/16 fuel line from AutoZone, slit it the full length with a razor and glued it to the trailing edge with 3M 1099. I think it looks pretty snappy.
As for bare vs having the shield, I highly recommend it. It does exactly what its purpose is - keeps the glare off of the panel displays, most notably during daylight when the sun is to the side or behind you.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"
- Several others that are now just great memories for me.
Old 05-18-2019, 08:21 AM
Tcox750 Tcox750 is offline
I used flocking on my glareshield on the suggestion of a friend. It looks nice, soft to the touch, and is very durable. One place I found it was here: https://www.flockit.com
Old 05-18-2019, 08:52 AM
Gash's Avatar
Gash Gash is offline
I used black automotive sub speaker cloth. It's very black, thin, easy to cut and fit into the small corners. Use a small amount of spray adhesive and lay it down. Pretty easy. Here's the link to the item on Amazon. For the edge, I used a very nice one from Classic Aero Designs. Those guys are great--highly recommended.
Karl, Goodyear, Arizona (KGYR)
RV-7, Flying
Extra 330LX, Flying
RV-8, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2019
