Old 05-15-2019, 04:48 PM
wrightmij3 wrightmij3 is offline
Default DYNON ADD SVGPS2020 TO EXISTING GPS 250.
I currently have a SV 250 gps mounted under the cowling, i am adding the gps 2020 to be complaint. I would like to keep the current gps 250 for redundancy. Where is the best place to mount the GPS 2020? On the front, in front of the canopy? Or aft of the canopy in the tail section. The installation manual from Dynon says questionable placement under the cowl. thanks for the help.
Old 05-15-2019, 05:22 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
Unless they changed things you cannot have two GPS sources since Vans used up all the serial ports for the Skyview on the RV-12. GPS works fine under cowl for either version.
Scott- 2019 dues paid
New RV-7A N579RV, 24 hours still in phase I
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
Old 05-15-2019, 05:24 PM
skydiverlv skydiverlv is offline
I have both Skyview gps pucks mounted on the Vans supplied gps bracket beneath the cowl and have no issues with performance.
Larry Vandegrift
ULPower 260is
Old 05-23-2019, 09:17 PM
If the serial ports are used up you could always put in a single pole double throw switch to select which GPS is providing data. Probably not kosher if you select the old GPS for the ADS-B Out position source.
