  #31
Old 01-08-2019, 08:47 AM
John C's Avatar
John C John C is offline
Default Effect of fuel pressure on float height
Originally Posted by NinerBikes View Post
Any ideas on if that additional fuel pressure is a consideration in Carb floats on the Bing Carbs turning into sinkers instead of floats? Does that fuel pressure cease to exist once the fuel enters the float bowl, since at that point, the carb jets are now creating lower pressure due to air stream through the throttle bore of the carb.
Fuel pressure at the float needle pushes down on the float arm. The net effect is about 1/3 of the float weight. The depth of the float will increase as the fuel pressure increases.
John Clark
Moundridge, KS
RV-9A 90512 N6699 Sold
RV-12 120323 N6699Z 410 hours
dues paid 2018
Old 01-11-2019, 04:49 PM
AJSWA AJSWA is offline
Default low fuel pressure
John C and RVBuilder2002 check your PM please.
Andrew
RV 120573
Old 02-03-2019, 05:53 AM
Default Vapor Lock
I read Kathrynís Report for continuing safety education. An accident in 2015 in California involved a Czech built LSA with Rotax 912ULS engine. The NTSB said the cause of the accident was attributed to fuel vapor lock which has been discussed many times in this forum.
SeeÖ http://www.kathrynsreport.com/2019/0...ccident_2.html
The airplane manufacturer didnít include a fuel return line with restrictor as Rotax installation requires. The airplane apparently flew successfully for 300TT and then developed vapor lock.
My takeaway on this accident is that this is analogous to shutting off the electric fuel pump in a RV-12. This topic has been discussed very thoroughly and can be searched for in this forum.
For what itís worth, Iíll restate my opinion that the RV-12 electric fuel pump should run all the time as designed by Vans Aircraft in order to mitigate vapor lock.
See alsoÖ http://www.kathrynsreport.com/2018/1...-accident.html
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 441
LSRM-A Certificate 2016
and MJ Stricker (CFI) - 1st Lt. Captain B-17H
Old 02-03-2019, 07:29 AM
Quote from NTSB report.
An examination of the fuel system revealed that when pressurized air was fed through the fuel filter, the air would not escape from the upper "y" fitting. Disassembly of the junction revealed that after the fuel filter there was a metered orifice installed that blocked air from continuing through the system
The NTSB report does not say that vapor lock was the cause of the accident.
Joe Gores
RV-12 Flying
Old 06-03-2019, 01:30 PM
MVPILOT MVPILOT is offline
Originally Posted by John C View Post
The airplane first flew in 2016.
It is good to hear that some using mogas are not having a problem.
I own a 2015 RV-12 SLSA with 220 hours. I have been using high octane no ethanol fuel purchased at KAWO except when I couldn't and then used 100LL. I've never had a fuel pressure problem until I had to start using 100LL last month. Yesterday in a climb it went quite low into the yellow zone and I turned around and landed. My questions are: could the switch to 100LL be part of the problem? What is the risk of the engine quitting during a climb with very low fuel pressure?
RV-12 KBVS Washington State
Old 06-03-2019, 05:33 PM
The switch to 100LL is likely unrelated. Chances are that the fuel pressure is not really low. Instead the fuel pressure sensor is inaccurate. Verify the fuel pressure before blaming the fuel or fuel pump.
Joe Gores
RV-12 Flying
