Old 06-03-2019, 02:50 PM
E. D. Eliot E. D. Eliot is offline
Default 912 - Gaskets, etc - What do I need?
Hoping to move my 12 parts to a hanger for assembly soon. I need to know which gaskets I need to have on hand in order to properly service my 912ULS during the first 50 hours or so. Thanks in advance.
Building finally
Old 06-03-2019, 03:16 PM
DHeal DHeal is online now
I suggest that you become very familiar with the Operator's Manual, Line Maintenance Manual, and Heavy Maintenance Manual for your ROTAX 912 ULS (https://www.rotax-owner.com/en/suppo...series-engines). Your first 25-hour inspection/maintenance task is critical and must be accomplished and documented in accordance with ROTAX's requirements if you are to maintain your engine warranty.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 770+ hours (as of May 2019)!
VAF donation through June 2019.
Old 06-03-2019, 08:12 PM
I maintain a couple of extra carburetor bowl gaskets, copper gaskets for the oil drain and magnetic plug and a couple of O-rings for the intake manifold.
Old 06-04-2019, 03:22 AM
The magnetic plug on the 912 gearbox does not use a gasket.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 441
LSRM-A Certificate 2016
and MJ Stricker (CFI) - 1st Lt. Captain B-17H
Old 06-04-2019, 10:05 AM
MMiller MMiller is offline
Rich was implying that there are two commonly used “Gasket Rings.” I’m sure he intended to say “crank locking pin plug” (42), not magnetic plug (35) there only a few mm apart.
Old 06-04-2019, 08:08 PM
Yep, Mike, I misidentified the locking pin plug.
I keep a lot of stuff in the hangar just in case, like an extra set of plugs. I mentioned the stuff I routinely need.
