Old 05-31-2019, 02:09 PM
DickB DickB is offline
Default EGT Probe Part #
My left EGT probe has failed after about 160 hrs. I tried to order one, but the Van's parts person was not sure of the part # for the RV12. The only part # for an EGT probe she could find was IE P-110. The plans just show it is part of the Dynon sensor kit. Does anyone know if this is the correct #?
RV12 ELSA, N233WB, s/n 120901, flying since Nov 2015.
Old 05-31-2019, 02:16 PM
DHeal DHeal is offline
I assume that you are talking about an RV-12/ROTAX 912 ULS. When I had to replace one of my EGT probes last year I went to Dynon's website (currently inop) and ordered a replacement probe (@ $30 as I recall). Just give Dynon a call. Be sure that you order the probe with the correct size hose clamp for your exhaust pipe diameter.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 770+ hours (as of May 2019)!
VAF donation through June 2019.
Old 05-31-2019, 02:21 PM
Thanks David, I will try Dynon. The EGT probe that the Van's parts person could find was $95, so it sounds like that is not the correct part.
Old 05-31-2019, 02:43 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default EGT part number
I just replaced one of mine with this one. It works.
Dynon prefers not to sell parts but probably will refer you to a distributor.
Available from AC Spruce Part no. 10-01844 for $36.00 plus shipping.
Tony
RV-12 #202 -- Flying
Old 05-31-2019, 02:51 PM
Thank you Tony! I sent Dynon a request message, but have not heard back from them. But from what you say, it may be a wasted effort. Aircraft Spruce will certainly be an easier path to take since I could use a few other things.
Old 06-01-2019, 04:17 PM
I heard back from Dynon on the EGT probe. They said they have it available on their Web Store for $36.00 - the same price as Aircraft Spruce.
