Old 05-13-2019, 11:12 PM
Tacco Tacco is offline
Default Vibration Sources
I have a vibration Iím tracking down. While Iím investigating the usual suspects, thought I might ask your thoughts on this possibility. Might be dumb but thought Iíd ask.
I have about 15 hours on the aircraft. Initial flights were smooth as butter. Carbs are balanced, prop is tracking and set accurately. The vibration is most noticeable through the stick as if itís a control surface issue.
Level cruise, 5000 RPM. Didnít have that until recent flight.
So hereís a thought: the earlier flights were conducted in cold weather and I never had the cabin vent open. Could an open cabin vent disrupt the propeller slip stream in such a way as to effect the elevator and/or rudder?
Old 05-13-2019, 11:43 PM
I have never noticed any control surface vibration with/without cabin vents open. Are your stabilator cables correct tension?
I'm curious why you're cruising at 5000 instead of 5500 - top of green arc?
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 441
LSRM-A Certificate 2016
and MJ Stricker (CFI) - 1st Lt. Captain B-17H
Old 05-14-2019, 06:47 AM
John-G John-G is offline
May just be something as simple as an unbalanced nose wheel rotating during flight.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 05-14-2019, 08:41 AM
DHeal DHeal is online now
Was your AP "off"? With the AP "on" you will feel some "vibrations/pulsations" through the control stick as the servos work to adjust the control surfaces.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 770+ hours (as of May 2019)!
VAF donation through June 2019.
Old 05-14-2019, 09:11 AM
JBPILOT JBPILOT is offline
Default Hey John - -
I had a nose wheel bolt too loose, and in fact the front tire was spinning and slightly out of balance. Check how tight it is and spin it on the ground and see how fast it stops spinning.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2019 )
Old 05-14-2019, 09:43 AM
I was doing the performance box from FT4 of the PAP.
Old 05-14-2019, 01:39 PM
DaleB's Avatar
DaleB DaleB is offline
I normally cruise at 5000 if I'm just cruising, to maybe 5300 if I'm in more of a hurry. I find that 5200-ish to 5500 burns a lot more fuel for only a couple of knots extra speed.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 05-15-2019, 08:26 AM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
+1 on the nose wheel. Although mine is an 8A, I painted a white stripe
on the tire and used a GoPro attached to the wing to verify it was
rotating (mine has a Grove nose wheel so there is no friction on the
bearings). Sure enough, it was rotating. Balancing the nose wheel
did the trick, no more vibration thru the control stick.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 05-15-2019, 07:46 PM
Thanks guys! It was indeed an out of balance nose wheel.
This forum is an awesome thing! It has saved me valuable time, significant frustration, and certainly some bucks. Iím sending in a donation. 😎
