Interesting reading Bruce, I did not know that about the rudder pedals. Thanks for sharing that. I will keep it in mind and look at how the brakes and rudder work together.Rudder pedal extensions.
I took this from Randy, that got it from...
http://www.romeolima.com/RV8/IdeasProducts.htm#IDEA: Rudder Pedal Extensions
As far as mods, the canopy guides on the tipper which keep the canopy centered while lowering it.
Some time back Doug Reeves and Jay Pratt posted a VAF video highlight all the mods Jay came up with for -8's going through his shop. Unfortunately, I couldn't find the video. Jay, Doug?
I remember watching it and was impressed with all the mods Jay had come up with.
Hard to beat the .50 cals! But mine's the 1/4" steel rod at the mid hinge point in the -8 ride pedals. I believe I was the first with that back in the day!
The windshield is my favorite mod...
i have it on my list of things to do to my rv. opening up the cowl exit helps the cooling but doesn't hurt the speed.
Good morning Eric,Hi Bryan,
I searched the forum for this but did not find anything on your 1/4" rod mod.
In a word (or photo) can you describe this mod?
You're going to make Dan's head pop off with that statement .
Finally, after my second annual/condition inspection, I decided it was time to stop swearing at this part every time I tried to get it in and out. Makes inspections, routine maintenance, and upgrades that require tunnel work much easier and, therefore, much more likely to get done!
I have to say the Removable Co-Pilot stick with the quick release button has been great on my 7. Only 56 hours into it but I've used it no less than 25 times whether it's for maintenance access to get under the panel, kiddo car seats, strapping in weight for test flights or the wife's comfort. Super easy to make and even easier to use.
I also like my fully hinged rudder pedals with brake return springs, cowling hinge covers and oil door hidden hinge and flush buttons, heated seats, grips fit just the way I like them, cowling exit ramp and no paint so I'm not afraid to take it apart and make more favorite modifications!
My best mod? Showplanes fastback canopy mod. Looks good, fast(er), amazing visibility, easy access behind panel when needed.
Dan, That tall mid-cabin weldment ever block view or get in the way flying??Second that, for sure. I'd never go back to a slider.
As an aside, the increase in rear baggage volume is a big deal. I've had full size folding chairs back there, and this past weekend a semi-hard shell suit bag.
The center roll bar is a big deal too....a tall, firm handhold to get all kinds of folks into the back seat.
Good morning Eric,
Basically, you install 1/4" steel rod across the mid section of the -8 rudder pedal. It acts as a point to push the pedal, but allows for easily *not* riding the brakes when you don't want to ride the brakes.
Couldn't find a decent photo. But linked below is a sketch of the mod over a stock pedal assy photo. Let me know if you have questions.
Bryan
https://lh4.googleusercontent.com/-...A/TlUKujm680I/w958-h719-no/rv-8+pedal+mod.jpg
Brent, do you have a write-up anywhere of how you did the sloped windshield mod? I'm fascinated - it looks incredible!
