Phantom30
I have a question for the "All Knowledgable" master builders on the forum.....so that I have sufficient part available. How many, and what degree alignment shims have you used to correct toe-in/Toe-out?
I'm sure I aren't the only one pondering this question....like the duuu question of where to place balancing weights on nose wheel.....or why the tube valve stem washer is to thick to start threads of nut on valve stem protruding thru wheel assembly. "Read all the info"!!!
