Old 02-04-2018, 08:33 AM
JOEPILOT JOEPILOT is offline
Default Glide ratio
Does anyone know the glide ratio for our planes?
Old 02-04-2018, 11:18 AM
AeroDog AeroDog is offline
A while back I watched a EweTube video (they're a bunch of sheep, but that's another story) where someone on this forum did a long, dead-stick, prop-stopped glide to landing. The claim was made that a -12 can do 12:1. That seems optimistic, but may be true.
Jerre
Empennage and fuselage kits complete
Wing kit compete, Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 02-04-2018, 11:27 AM
az_gila's Avatar
az_gila az_gila is online now
Smile
It will vary depending on lots of obvious variables, however one data point is here for a RV-6A in a CAFE Foundation test -
11.39:1
https://www.yumpu.com/en/document/vi...afe-foundation
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-04-2018, 12:18 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default RV9A Cafe
The Cafe report for the RV9A shows 12 to 1 at 1738lbs and 95mph.
Edit: Idle power coarse pitch
John Morgensen
RV-9A N946PM 500+ hours since 2013
Nevada/Arizona
Last edited by JohnInReno : 02-04-2018 at 12:55 PM. Reason: Additional information
Old 02-04-2018, 12:47 PM
rongawer's Avatar
rongawer rongawer is offline
Default Other airplanes for reference
12:1 sounds reasonable to me with the prop stopped; probably closer 10:1 if the prop is still spinning (due to the extra drag).
For reference, my Baron B58 with feathered props is 10.5:1 and the B747-200 is 15:1.
Ron Gawer
- RV12, N975G, Phase 1 testing
- BE58, N1975G, stimulating the economy one flight at a time.
Old 02-05-2018, 08:50 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I recently had an engine fuel delivery problem. I shut down and stopped the prop and got over 3 minutes of glider time. I held 60 kts, and averaged 582 fpm descent by Dynon. Solo with full fuel. Do the math and it is 10.43 for my plane for those conditions. Only a final turn from a 45 for final. The Dynon pretty much had the glide distance nailed.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 235 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 02-05-2018, 10:40 PM
donaziza's Avatar
donaziza donaziza is offline
Default Anybody got numbers for an 8?
Old 02-05-2018, 11:54 PM
Bevan Bevan is offline
Do the test cards for YOUR plane then make a POH for YOUR airplane. You will learn a bunch. Iím surprised this isnít required to finalize the Phase 1 period.
Bevan.
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-06-2018, 04:22 AM
JohnInReno's Avatar
Default RV8A
All of the Cafe Foundation reports are available here:
http://cafe.foundation/v2/research_aprs.php
John Morgensen
Nevada/Arizona
Old 02-06-2018, 05:41 AM
beechrv9a's Avatar
beechrv9a beechrv9a is offline
Default Thanks!
Thanks for Posting!
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
177 Cardinal N3156T
Beechrv9a@hotmail.com
