Old 02-17-2018, 05:05 PM
DHeal DHeal is offline
Data point: I installed the pitot bushing in 5/2013 using "blue Loctite" per Van's plans. Four years and 600 flight hours later the bushing is doing very well with no sign of loosening.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 02-17-2018, 07:42 PM
The loctite was originally specified because it was something that was needed during the engine installation, and it would be needed for maintaining the engine in the future.
It works well if the fit of the busing is the desired level of clearance with the hole diam. that is specified, but apparently that can vary more than desired and some people have had them come loose, so the new plans for the iS airplane will be specifying using tank sealant.
It is fairly viscous so does a good job of gap filling if needed, and because it is flexible it will assure that differences in expansion/contraction will not be a factor (if there is a chance that that also was, but that is unknown).
Scott McDaniels
Hubbard, Oregon
Old 02-17-2018, 11:45 PM
Vakashi Vakashi is offline
Thanks Scott, you always do a great job of clarifying the thinking behind so many aspects of the build that have us builders perplexed.
