Old 07-08-2018, 05:02 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default RTV? Maybe..
I would prefer one of the gasket maker products, unless you have the gasket on hand. Not all RTV types are oil proof.
Which one to use? Well: https://www.permatex.com/
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 07-08-2018, 06:56 PM
jump4way jump4way is offline
Iím following along on this post because I am near first engine start with my SDS system. Thanks to all that have posted so far. Iím a bit unclear of the pointer and the mark part. A picture would help me a ton. Does anyone have a photo of that part of the process?
Thanks.
Old 07-08-2018, 07:08 PM
Dustyone Dustyone is offline
Default Post 17 for pictures
Hi all who have asked for photos on timing.
Go to this post and photos start at Post 17
http://www.vansairforce.com/communit...=140051&page=2
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 600hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 07-08-2018, 07:15 PM
Toobuilder's Avatar
Thanks.
Mike S has a good write up. Look here: http://www.vansairforce.com/communit...38&postcount=3
It's important not to over think the pointer thing. All you have to do is establish that the engine is in the desired position for firing using the factory timing marks or other means, and step #2 is to add a pointer "anywhere convenient" on the ring gear. Wherever that pointer falls, simply mark that point. That is now your new "desired position".
Michael Robinson
______________
Harmon Rocket II -SDS EFI instalation in work
RV-8 - Flying
1940 Taylorcraft BL-65 -flying
Old 07-08-2018, 07:58 PM
Thanks, both of those posts help tremendously.
Old 07-12-2018, 03:54 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Timing Pointer Ideas
Ralph Inkster came up with this simple way to project a pointer to use the rear flywheel timing marks.
He used a long drill bit and some duct tape to extend the case split centerline.
He put some additional marks on the flywheel as well.
Hope this idea helps out a few folks in this area.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 432.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 07-12-2018, 06:57 PM
maus92 maus92 is offline
That is similar to what I set up with piano wire from a seat hinge. Now building a stable platform to stand on while aiming the timing light, trying to avoid being macerated by the prop.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 07-12-2018, 07:35 PM
rv6ejguy's Avatar
I don't think there is any need to be within 2 feet of the prop but you could also tape the timing gun in place and a video camera or phone, zoomed in with the monitor screen facing you in the cockpit.
I hope to show a couple ways to do it in the upcoming videos on the RV6 and -10.
Old 07-16-2018, 06:57 AM
I need to verify the config for my G3X RPM2 input that utilizes the green tach wire from the control box. How many pulses per rev does it output? I think it's two, but I need to verify.
CA
Old 07-16-2018, 07:48 AM
rv6ejguy's Avatar
Yes, 4 cylinder systems output a 12V tach signal, 2 pulses per crank rev.
