acam37
0320/E2G with 30 hrs SMOH. almost every flight it will momentarily stumble for a split second. It can best be described as a (bump). After that it runs fine the rest of the flight. It will only do it once. We changed both mags, wires, and plugs and it still does it. I cant figure out what could be causing this? The plane is going to Sun-N-fun which is 1000 miles one way. I would like to find out if this is a major issue or just an annoyance?
