Old 01-24-2018, 10:07 AM
8 Builder 8 Builder is offline
Default Lemo jack for Bose A20
Hi all- I have a couple of questions. After searching for two days, I can not find the site that had what for me seemed like the perfect way to route the wiring for my front and rear Infinity sticks. The builder had the rear stick wires exit the rear stick, do a stress relieving loop and then go through the F-814C-R with a d sub connector. It had great pictures. NO CAN FIND! Any help appreciated.
The other question is regarding wiring a Bose A20 headset to the Garmin GTR 200 using ONLY the Lemo Jack without the GA plugs. Neither garmin or Bose were able to help me. Of course the only post that said that they had just what I needed was not there anymore. Thanks, Rich
Rich Snyder
Building RV-8
Superior IO-360
Garmin G3X Touch VFR
Planning for Fixed Catto 3 blade
Old 01-24-2018, 10:22 AM
sergioam2009 sergioam2009 is offline
Red face Why not both plugs?
Just a silly question: why don't you install both types of plugs, LEMO and regular dual plugs? Suppose in the future yourself or a passenger brings in a conventional headset, or you want to sell your plane, wouldn't it be better to have more ample choices than to narrow them from the start?
Considering building... In Brazil
Old 01-24-2018, 10:25 AM
wjb's Avatar
wjb wjb is offline
I'm using the Lemo plugs (in parallel with the standard jacks) with a GTR20 (non panel mount version of GTR200) ... what's your question?
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine hung!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 01-24-2018, 03:46 PM
Peter Costick Peter Costick is online now
I installed Bose Lemo plugs using the standard diagram supplied by Bose and just omitting the standard jacks. So far it seems to work fine.
I did contact Bose by email but they didn't even reply.
Peter Costick
Melbourne Australia
RV7A, VH-SVN
2018 Donation Made
Old 01-24-2018, 08:30 PM
RV6_flyer's Avatar
IF you only install the LEMO jacks and someone comes along wanting to use the standard headset plugs, there is an adapter cable that will allow you to use them.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-25-2018, 06:09 AM
Sergio- I thought about this and did install both plugs for the passenger. I just want to keep it simple up front and only have the LEMO. I have the adapter for LEMO to GA. All of the literature included with the LEMO shows it connected to GA plugs. I am NOT an electrician or avionics tech and would be more comfortable following a schematic showing only the LEMO to GTR 200. As I mentioned; no help from Garmin or Bose.
Rich Snyder
Building RV-8
Superior IO-360
Old 01-25-2018, 06:13 AM
Default LEMO
My question is how to wire ONLY the LEMO jack for the pilot. No GA plugs involved. I can make a good guess as to how it would be done by looking at the GA/LEMO schematic but I don't want to guess.
Rich Snyder
Building RV-8
Superior IO-360
Old 01-25-2018, 06:32 AM
RV6_flyer's Avatar
Connect as recommended BUT leave out the GA jacks. The signals are the same but the GA Jacks are left out.
Here is the wiring. Do NOT connect the GA Jacks to give what you want.
Page 35 of the BOSE A20 manual show the wiring of the LEMO Jack. Page 36 shows the wiring with GA Jacks that are Stereo and Mono.
It does not matter if you are not using a BOSE headset in the LEMO jack, the wiring for LEMO jack is the same for all manufacturers.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Old 01-25-2018, 06:57 AM
vlittle's Avatar
vlittle vlittle is offline
Another version showing both Lemo and GA plugs, but also with an aux power jack for other types of ANR headsets.
http://www.vx-aviation.com/sprocket/...s-2/AUDIO2.pdf
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 01-26-2018, 06:52 AM
Danny King's Avatar
Danny King Danny King is offline
Default LEMO only
I gave this some thought back in the late 90's when I purchased a pair of Bose X headsets. Should I put in the standard mic and phone jacks along with the LEMO jack? I ask myself: "When will I ever fly the Doll when I'm not going to use the Bose X ?" I decided that the answer was never!
Fast forward nearly 18 years. The wife and I gave each other Bose 20 headsets for Christmas a few years back, and I have never found a need to fly the Doll with any other headset. The Bose X was good but, IMHO the Bose 20 is the finest headsets on the market. Several passengers have purchased their own Bose headsets after flying in the Doll and discovering for themselves what they had been missing. Right Jay Pratt?
The LEMO plug make it simple and it does it all. Phone, Mic, and ship's power for the ANR. Bose makes a LEMO harness which makes the wiring neat and tidy. If you already have standard jacks then you can add the LEMO harness and tap into the Mic and Phone jack.
Tailwinds.
Danny King
Beautiful Doll 80434 TT 1565 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2018
